problem with alpha in running
Old   November 29, 2014, 11:22
Default problem with alpha in running
minoominaii
bgane67 is on a distinguished road
i want to simulate droplet pich off in a nuzzle which is above a cylinder,but when solve my example with interfoam my error is:
Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/niloofar/Desktop/nuzzle1/0/alpha.water at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
my alpha1 folder is :
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object alpha1;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
fixedWall
type zeroGradient;
axis
type zeroGradient;
front
type wedge;
back
type wedge;
and my setfieldsDict is :
| \\ / O peration | Version: 2.2.0 |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object setFieldsDict;
defaultFieldValues
volScalarFieldValue alpha1 0
regions
boxToCell
box (0 0 0) (1 0.5 0);
fieldValues
volScalarFieldValue alpha1 1
my p-rgh is:
| \\ / O peration | Version: 2.2.1 |
FoamFile
version 2.0;
format ascii;
location "0";
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
inlet
type fixedValue;
value uniform 0.0001;
outlet
type fixedValue;
value uniform 0;
fixedWall
type zeroGradient;
axis
type fixedValue;
value unifrom 0.0001;
front
type wedge;
back
type wedge;
my u folder is:
| \\ / O peration | Version: 2.1.0 |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0.003 0 0);
outlet
type zeroGradient;
fixedWall
type fixedValue;
value uniform (0 0 0);
axis
type zeroGradient;
front
type wedge;
back
type wedge;
thank you so much.
bgane67 is offline   Reply With Quote
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 13:30
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
Problem while running in Highperformance computing environment Phanipavan STAR-CD 1 September 11, 2013 06:42
problem with running in parallel dhruv OpenFOAM 3 November 25, 2011 05:06
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
