interFoam - steady current: air in water
Old   April 5, 2020, 14:09
Default interFoam - steady current: air in water
Jente Vercammen
Jekke123456789 is on a distinguished road
I am a searching for a solution of my problem, I am trying to check the velocities at a rock berm at the sea bottom for a steady current. Later one waves will be added but that are problems for later. I am using OpenFOAM v1812.
Specifics:
- current 0.49 m/s
- beach at the end
Main problems:
- air inside the water at the inlet.
- increase of water height in time (need to be constant)
The mesh is easy, with the use of stl file . It consist out of a berm and a beach at the end. See attachment.
These are some files that could be useful, if anything else is needed, let me know:
BlockMesh:
x-axis: 0 – 35
y-axis: 0.01 – 0.06
z-axis: 0 – 3
hex (0 1 2 3 4 5 6 7) (700 1 60) simpleGrading (1 1 1) //5cm fo each cell in x and z direction
Everything type: Patch, later on sides are set to empty
Set fields:
defaultFieldValues
    volScalarFieldValue alpha.water 0
    volVectorFieldValue U           (0. 0. 0.)
regions
    boxToCell
        box (0 0.01 0) (35 0.06 0.750);
        fieldValues
            volScalarFieldValue alpha.water 1
            volVectorFieldValue U           (0.49 0. 0.)
Boundary conditions:
alpha.water:
    inlet
        type            zeroGradient;
    inlet // I tried this too, but then the whol inlet was water instead of only a height o 0.75
        type            fixedValue; 
        value           uniform 1;
    outlet
        type            zeroGradient;
    ground
        type            zeroGradient;
    sides
        type            empty;
    top
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
U:
  inlet
        type            fixedValue;
        value           uniform (0.49 0 0);
    outlet
        type            fixedValue;
        value           uniform (0. 0 0);
    ground
        type            fixedValue;
        value           uniform (0 0 0);
    sides
        type            empty;
    top
        type            pressureInletOutletVelocity;
p_rgh:
inlet
        type            fixedFluxPressure;
        value           uniform 0;
    outlet
        type            zeroGradient; 
       // value           uniform 0;
    ground
        value           uniform 0;
    sides
        type            empty;
    top
        type            totalPressure;
        p0              uniform 0;
Results:
air at inlet See attachment
Rise of waterheight starting at the beach See attachment
So now the problems can be seen in the figures, I just want a steady state flow a the inlet, without air that is commin in to the water.
I tried it without the beach and have a uniform value of 0.49 at the outlet but still air is at the inlet.
Is there a way to set a boundary condtion only to the water part?
Any other suggestion is welcome for a steady state current with interFoam!?
Jekke123456789 is offline   Reply With Quote
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 14:33
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 14:27
I am NOT getting right pressure at the air inlet in water column kcfd FLUENT 0 November 24, 2012 23:14
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
VOF-compression of air with rising water yavuz FLUENT 0 November 26, 2005 09:00
