Jente Vercammen
Rep Power: 4 ![]() |
interFoam - steady current: air in water
I am a searching for a solution of my problem, I am trying to check the velocities at a rock berm at the sea bottom for a steady current. Later one waves will be added but that are problems for later. I am using OpenFOAM v1812. Specifics: - current 0.49 m/s - beach at the end Main problems: - air inside the water at the inlet. - increase of water height in time (need to be constant) The mesh is easy, with the use of stl file . It consist out of a berm and a beach at the end. See attachment. These are some files that could be useful, if anything else is needed, let me know: BlockMesh: x-axis: 0 – 35 y-axis: 0.01 – 0.06 z-axis: 0 – 3 hex (0 1 2 3 4 5 6 7) (700 1 60) simpleGrading (1 1 1) //5cm fo each cell in x and z direction Everything type: Patch, later on sides are set to empty Set fields: defaultFieldValues ( volScalarFieldValue alpha.water 0 volVectorFieldValue U (0. 0. 0.) ); regions ( boxToCell { box (0 0.01 0) (35 0.06 0.750); fieldValues ( volScalarFieldValue alpha.water 1 volVectorFieldValue U (0.49 0. 0.) ); } ); Boundary conditions: alpha.water: inlet { type zeroGradient; } /* inlet // I tried this too, but then the whol inlet was water instead of only a height o 0.75 { type fixedValue; value uniform 1; } */ outlet { type zeroGradient; } ground { type zeroGradient; } sides { type empty; } top { type inletOutlet; inletValue uniform 0; value uniform 0; } U: inlet { type fixedValue; value uniform (0.49 0 0); } outlet { type fixedValue; value uniform (0. 0 0); } ground { type fixedValue; value uniform (0 0 0); } sides { type empty; } top { type pressureInletOutletVelocity; value uniform (0 0 0); } p_rgh: inlet { type fixedFluxPressure; value uniform 0; } outlet { type zeroGradient; // value uniform 0; } ground { type fixedFluxPressure; value uniform 0; } sides { type empty; } top { type totalPressure; p0 uniform 0; } Results: air at inlet See attachment Rise of waterheight starting at the beach See attachment So now the problems can be seen in the figures, I just want a steady state flow a the inlet, without air that is commin in to the water. I tried it without the beach and have a uniform value of 0.49 at the outlet but still air is at the inlet. Is there a way to set a boundary condtion only to the water part? Any other suggestion is welcome for a steady state current with interFoam!? |
Display Modes | |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 15:27 |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 9 | April 2, 2018 03:27 |
I am NOT getting right pressure at the air inlet in water column | kcfd | FLUENT | 0 | November 25, 2012 00:14 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
VOF-compression of air with rising water | yavuz | FLUENT | 0 | November 26, 2005 10:00 |
