Unrealistic results using DPMFoam
Like Tree1Likes
  • 1 Post By maysmech
Old   January 14, 2015, 13:28
Default Unrealistic results using DPMFoam
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
I am rather new to DPMFoam. I wanted to simulate a very simple T-Junction problem, in which there is one inlet and two outlets.
You can see the images. The first image is done using icoFoam, and there is no problem in here.
The second image is using DPMFoam, I have disabled the coupling between the continuous phase and particles.
I am focusing on the continuous phase. But I can not get the results obtained previously by icoFoam.
What am I doing wrong?
You can get the DPM case from the link below:
https://www.dropbox.com/s/726lc9bdt3...PM.tar.gz?dl=0
Thanks,
Mojtaba.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   January 22, 2015, 14:06
Mojtaba.a's Avatar
Are there any suggestions ?!
I just want to make similar results to icoFoam using DPMFoam in which I have disabled all particle forces.
I am trying to first validate the results obtained by solving fluid equations and then solving for particles.
I would really appreciate if somebody could help.
Thanks.
Old   January 24, 2015, 02:52
maysmech's Avatar
maysmech is on a distinguished road
Thanks.
Check the kinematic viscosity and density of fluid phase.
The reason behind the unrealistic result is gravity effect on fluid. When I turned off the gravity the result was ok, so it is because of 1) small inlet velocity magnitude, 2) viscous and dense fluid phase
You didn't send the icoFoam case but I think you used air properties there and are using something like water properties here.
maysmech is offline   Reply With Quote
Old   January 24, 2015, 03:40
Mojtaba.a's Avatar
Originally Posted by maysmech View Post
Thank you for your fast response.
Well, you were right. All I wanted to do was to disable gravity. I am getting nice results now.
Regarding the kinematic viscosity and density of the fluid, I am not using air nor water properties for my simulation. Actually I am trying to simulate a very viscous fluid.
There is another question I have. By disabling gravity I have disabled the weight force induced on both fluid and particles. How can I include the weight force on particles and not on the fluid phase?
Thank you,
Best.
Old   January 24, 2015, 10:28
maysmech's Avatar
I didn't suggest to turn off gravity to reach true answer. It was a trick to find the source of difference between icoFoam and DPMFoam results. So If you want compare both solvers you need to use similar properties, especially the density.
Mojtaba.a likes this.
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
Oscillating Airfoil Poor Results at High k (reduced frequency) dancfd OpenFOAM Running, Solving & CFD 3 November 4, 2013 08:32
CFD results not close to experimental results cider STAR-CCM+ 0 July 8, 2013 07:53
Creating a tool to interpolate results Luis Batista OpenFOAM Running, Solving & CFD 2 April 11, 2013 08:15
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 18:47
