OpenFOAM on a Odroid C1 ARM cluster
Old   February 11, 2015, 09:26
Default OpenFOAM on a Odroid C1 ARM cluster
Thomas Schulz
cico0815 is on a distinguished road
Hello everyone ...
during my latest tests I came to a point where I had to use a lot of
computational power (cases ran up to weeks). I wanted to investigate
further and tried to find out something about power consumption and
the power to watt ratio. I build myself a small Archlinux based ARM
cluster (6 nodes) using the new Odroid C1 boards.
They are now installed and the distribution runs fine. MPI test programms
compiled using openMPI and MPICH.
I am now to the point where I would like to run some testcases with
OpenFOAM (my latest cases where build and run using version 2.2.2).
I am using my laptop (x86 based with Xubuntu 14.04 installed) as a head
node and data storage. The nodes all got a 16 GB SD card installed and
are connected to a gigabit ethernet switch. A passwordless ssh login for
my cluster user ('wolf' in this case) is possible from the head node to the
slave nodes and the other way around too.
If I issue the command:
/opt/openmpi/bin/mpirun -mca plm_rsh_no_tree_spawn 1 -np 24 -hostfile hostfile.openmpi /opt/openfoam/OpenFOAM/OpenFOAM-2.2.2/bin/foamExec icoFoam -parallel -case /opt/cases/cavity
the solver starts to run up to a point (random it seems) and then just
hangs there. Nothing happens anymore ... no output, no error message
(find the output up to that point at the end of this post).
Logging into one of the nodes and start a "top" the cores are still under
load but in the output there is nothing anymore. Does anyone can give me
a hint on what might be wrong here? Anyone had a similar problem?
Best, Thomas
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.2-9739c53ec43f
Exec   : icoFoam -parallel -case /opt/cases/cavity
Date   : Feb 11 2015
Time   : 14:16:40
Host   : "cluster02"
PID    : 2599
Case   : /opt/cases/cavity
nProcs : 24
Slaves :
23
"cluster02.2600"
"cluster02.2601"
"cluster02.2602"
"cluster03.1912"
"cluster03.1913"
"cluster03.1914"
"cluster03.1916"
"cluster04.1874"
"cluster04.1875"
"cluster04.1876"
"cluster04.1878"
"cluster05.1987"
"cluster05.1988"
"cluster05.1989"
"cluster05.1991"
"cluster06.1847"
"cluster06.1848"
"cluster06.1849"
"cluster06.1851"
"cluster07.1750"
"cluster07.1751"
"cluster07.1752"
"cluster07.1754"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.005
Courant Number mean: 0 max: 0
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 5.52301e-06, No Iterations 14
DILUPBiCG:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG:  Solving for p, Initial residual = 1, Final residual = 6.39255e-07, No Iterations 61
time step continuity errors : sum local = 4.27023e-09, global = -4.23516e-20, cumulative = -4.23516e-20
DICPCG:  Solving for p, Initial residual = 0.523593, Final residual = 5.26347e-07, No Iterations 60
time step continuity errors : sum local = 5.83689e-09, global = 8.14773e-20, cumulative = 3.91256e-20
ExecutionTime = 0.43 s  ClockTime = 1 s
Time = 0.01
Courant Number mean: 0.0976806 max: 0.585722
DILUPBiCG:  Solving for Ux, Initial residual = 0.148584, Final residual = 5.69895e-06, No Iterations 12
DILUPBiCG:  Solving for Uy, Initial residual = 0.256618, Final residual = 9.01967e-06, No Iterations 12
DICPCG:  Solving for p, Initial residual = 0.379084, Final residual = 6.6662e-07, No Iterations 59
time step continuity errors : sum local = 6.22843e-09, global = -1.23912e-19, cumulative = -8.4786e-20
DICPCG:  Solving for p, Initial residual = 0.28687, Final residual = 8.18003e-07, No Iterations 58
time step continuity errors : sum local = 8.31983e-09, global = 8.18578e-19, cumulative = 7.33792e-19
ExecutionTime = 0.79 s  ClockTime = 1 s
Time = 0.015
Courant Number mean: 0.14468 max: 0.758278
DILUPBiCG:  Solving for Ux, Initial residual = 0.0448619, Final residual = 3.99534e-06, No Iterations 11
DILUPBiCG:  Solving for Uy, Initial residual = 0.0782148, Final residual = 5.47164e-06, No Iterations 11
cico0815 is offline   Reply With Quote
Old   February 11, 2015, 14:24
Default [Solved] ...
Thomas Schulz
Hi everyone ...
this was obviously a version problem with openMPI. I used the most recent
version from the webpage
http://www.open-mpi.org/software/ompi/v1.8/
After reading a bit I tried the openMPI version 1.6.3 that was included in the
ThirdParty archive for OpenFOAM 2.2.2 and ... problem solved! :-)
Cases are running fine now ... anyway ... anybody who can tell me why
the most recent version 1.8.4 of openMPI didn't work? What is the
difference? I read something about "thread support"??
Best, Thomas
Old   February 11, 2015, 15:25
Retired Super Moderator
Bruno Santos
Greetings Thomas,
A bit of a quick possible-answer list, based on what I know:
  • OpenFOAM 2.3 was developed and tested with Open-MPI 1.6.3. Older versions are known to work, but newer versions are always a shot in the dark.
  • Open-MPI 1.8.4 might have a feature that OpenFOAM 2.3 is not taking into account.
  • Or the Open-MPI 1.8 series isn't as "stable" as advertised on the page you provided.
  • It has happened in the past that some Open-MPI versions did not work properly with OpenFOAM. I can't remember the exact details, but I vaguely remember it had to do with some MPI feature that OpenFOAM used and which wasn't working properly in a specific Open-MPI version.
Best regards,
Bruno
Old   February 12, 2015, 15:18
Default Cluster tuning/tweaking?
Thomas Schulz
Hello Bruno,
now that the cluster is running and doing it's work I wonder if there are
ways to tweak the performance?
Are there ways to calculate the ideal processor / number of cells ratio?
I think the bottleneck is the communication between the nodes and this
slows the whole thing down considerably. I would like to get as much out
of those little boards as possible.
Best, Thomas
Old   February 14, 2015, 11:24
Bruno Santos
Quick answer: see my blog post Notes about running OpenFOAM in parallel
Old   June 21, 2016, 22:20
Default Did it went well?
Gabriel
gm2gabriel is on a distinguished road
Hi Thomas,
Could you share more information about your odroids Cluster, please?
I just bought a pair of Odroid-C2 for testing and I am trying to figure out how good could be a small cluster of Odroids in comparison with a workstation of the same price.
Best Regards,
Gabriel
gm2gabriel is offline   Reply With Quote
Old   June 22, 2016, 02:49
Default Project closed ... Odroids sold...
Thomas Schulz
Dear Gabriel,
the project I was working on has been finished and closed. I already sold the Odroids and I am currently not into OpenFOAM at all.
I am sorry to not being able to help you here.
Best,
Thomas
openFOAM mpirun error on cluster cheng1988sjtu OpenFOAM Running, Solving & CFD 1 November 14, 2012 22:13
Openfoam installation on beowulf cluster lalupp OpenFOAM Installation 2 April 9, 2012 10:24
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
OpenFOAM on cluster markh83 OpenFOAM Installation 1 October 17, 2008 19:09
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
