Boiling Flow in Minichannels
Old   August 11, 2014, 16:07
Default Boiling Flow in Minichannels
Parisa
Parisa_Khiabani is on a distinguished road
Hello OpenFoam experts,
I would like to simulate flow boiling in a channel flow, say minichannels. Is there any available solver in OpenFOAM to model that? For sure, I would like to use VOF.
I really appreciate your kind advice and help.
Cheers,
Parisa
Parisa_Khiabani is offline   Reply With Quote
Old   August 11, 2014, 17:16
Parisa
I am really anticipating your helps, guys,
Thanks a lot,
Parisa
Old   August 12, 2014, 07:02
Parisa
Nobody?
Old   August 12, 2014, 08:56
seav is on a distinguished road
What kind of medium you want to simulate ? Compressible or incompressible ?
I would suggest you this scroll down to Multiphase section. Maybe you will find something interesting.
cheers
seav
Cheers,
seav
"OpenFOAM is like a strict teacher, won't let you through until all is correct or better say until one has understood the sensitivities of a problem." -jaswi
seav is offline   Reply With Quote
Old   August 12, 2014, 10:50
Parisa
Thanks for your response,
I would like to simulate incomprehensible using VOF. I think twoPhaseEulerFoam is OK to start with. However, I would like to know about the limitations of this solver. Or any suggestion?
Old   August 12, 2014, 11:32
I have never used this solver. Only tip I can give you is to explore ~/OpenFOAM-version/applications/solvers/multiphase/twoPhaseEulerFoam/ *.H files, *.C files and all others.
seav
Cheers,
seav
Old   August 12, 2014, 12:16
Parisa
Thanks a lot,
Yes, I am working on them.
Cheers,
Parisa
Old   August 12, 2014, 12:52
Retired Super Moderator
Bruno Santos
Greetings to all!
A word of caution: there have been a few threads on the OpenFOAM sub-forums discussing whether it was possible to simulate VOF in a micro scale. So far I have not seen any positive feedback on this being possible.
The closest I've seen has been the possibility to observe the capillary effect, as demonstrated by the tutorial "multiphase/interFoam/laminar/capillaryRise".
Best regards,
Bruno
Old   August 12, 2014, 12:56
Parisa
Thanks wyldckat,
However, my case is not in micro scale. Suppose that I am simulationg boiling flow in macro scale. Do you know any valid solver? I would like to use VOF. What do you think about twoPhaseEulerFoam?
Thanks
Old   August 12, 2014, 13:23
Bruno Santos
Since you stated the following in the first post:
say minichannels
I assumed the worst case scenario, since "minichannels" would likely be in the millimetre scale, which could be close enough to micro scale.
Unfortunately I'm not familiar with any solver in OpenFOAM which provides the ability to solve boiling fluid flow. From what I can see on the page Seav suggested, none of the existing solvers in OpenFOAM 2.3.0 will be able to simulate this.
A quick search with Google about "OpenFOAM boiling" lead me to this thread: http://www.cfd-online.com/Forums/ope...hangefoam.html
edit: I vaguely remembered something named "evap" in OpenFOAM... oh, I have a solver named evapVOFHardt built in my environment for OpenFOAM 2.3. Looks like I handled a quick port of it for OpenFOAM and provided it here: https://github.com/wyldckat/evapVOFHardt
The original source code and documentation is provided here: http://www.ttd.tu-darmstadt.de/forsc...vofhard.en.jsp
Old   August 12, 2014, 16:25
Wouter van der Meer
wouter is on a distinguished road
Hello Parisa_Khiabani
this thesis is about boiling as far as I can tell
Development and validation of a two-phase CFD model
using OpenFOAM
Alberto Ghione
hope this helps
Wouter
wouter is offline   Reply With Quote
Old   August 12, 2014, 17:34
Parisa
Dear wouter,
Thanks for your kind help.
Parisa
Old   August 13, 2014, 06:29
Joachim Herb
jherb is on a distinguished road
Also have a look at this thesis:
https://mediatum.ub.tum.de/node?id=1172612
jherb is offline   Reply With Quote
Old   August 13, 2014, 10:32
Markus Rehm
markusrehm is on a distinguished road
you could also check this:
http://www.cfd-online.com/Forums/ope...se-change.html
http://openfoamwiki.net/index.php/Co...haseChangeFoam
Please report your experience.
Markus
markusrehm is offline   Reply With Quote
Old   August 28, 2014, 02:27
Mohammad Bahreini
mecman is on a distinguished road
If you want use VOF method for simulation , you should make own solver and implement mass transfer model foe phase change
Best
mecman is offline   Reply With Quote
Old   March 24, 2015, 19:31
james wilson
jameswilson620 is on a distinguished road
check this post out: http://www.cfd-online.com/Forums/mai...tml#post538055
jameswilson620 is offline   Reply With Quote
bubble diameter definition in multi phase flow boiling simulation FLUENT Abishek FLUENT 13 July 1, 2019 12:12
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 21:08
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
