Problem with parallel run
Old   March 30, 2015, 08:15
Default Problem with parallel run
António Pires
Antoniorp is on a distinguished road
Hello everyone,
I'm using ihfoam to simulate a wave flume.
I've done some runs in parallel without any problem but now i'm doing a new one and, when i use the command reconstructPar, i get this error message
Time = 14.65
Reconstructing FV fields
Reconstructing volScalarFields
p
nut
--> FOAM FATAL IO ERROR:
error in IOstream "/home/antonio/IHFOAM/IHFOAM_materials/tutorials/OF222/Klopman_bicromatico/Klopman-kepsilon/processor1/14.65/nut" for operation operator>>(Istream&, List<T>&) : reading entry
file: /home/antonio/IHFOAM/IHFOAM_materials/tutorials/OF222/Klopman_bicromatico/Klopman-kepsilon/processor1/14.65/nut at line 1357.
From function IOstream::fatalCheck(const char*) const
in file db/IOstreams/IOstreams/IOstream.C at line 114.
FOAM exiting
The first time i got this mistake it was for time = 30 s and i thought that maybe something had gone wrong when doing the simulation so I deleted everything and did the simulation again. Again i got this error message, this time for time = 14.65 s.
I really don't know why this happens because every file in the case folder is a copy from cases that already have worked correctly. Additionally, when running ihFoam i get no error at all, only when reconstructing.
Any ideia on why is this happening?
Thanks
António
Antoniorp is offline   Reply With Quote
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 12:08
nonNewtonianIcoFoam - problem with parallel run chris_sev OpenFOAM Bugs 4 April 1, 2009 09:13
Parallel run with engineFoam francesco OpenFOAM Bugs 1 November 25, 2008 07:06
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 17:11
