varying rho value in interfoam
Old   August 2, 2012, 06:39
Default varying rho value in interfoam
shiv
shash is on a distinguished road
hi all openfoamers,
i have been trying to inculcate a variable rho for one of the phases in openfoam but could not do it , rho has been defined as dimensionedscalar in interfoam for both phases but i want volscalarfield for at least one of the phases, can someone help me with this
shash is offline   Reply With Quote
Old   August 2, 2012, 23:24
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
interFoam calculates rho with a color function (alpha) weight. Off the top of my head, for a particular cell the density rho=rho1*(alpha)+(1-alpha)*rho2. If you are trying to alter one of the density fields you might have to get fancy with the density treatment.
kmooney is offline   Reply With Quote
Old   August 2, 2012, 23:38
kmooney's Avatar
Kyle Mooney
In order to make this change you'll need to declare a density field (volScalarField) and change out the density and viscosity computation in /src/transportModels/incompressible/incompressibleTwoPhaseMixture
To perform the computations in the two phase mixture library you might have to do a database look up to grab the density field you made above. I'll try to find some syntax to make that easy.
Old   August 2, 2012, 23:47
kmooney's Avatar
Kyle Mooney
Assuming you declared the density field correctly, you could try this in the twoPhaseTransportProperties library,:
const volScalarField& rho =
mesh().lookupObject<volScalarField>("myRhoField");
Old   August 4, 2012, 03:29
shiv
thanks kyle for ur detailed answer , i already tried creating volscalarfield for rho2 but didn't really know where else changes need to be done , i will try ur changes .
Old   August 4, 2012, 06:57
Nima Samkhaniani
nimasam is on a distinguished road
look at compressibleInterFoam, it gives you the idea how to implement a varialbe rho! in that solver rho is varying by pressure!
nimasam is offline   Reply With Quote
Old   August 11, 2012, 14:51
shiv
@nimasam : can i just change p from the rho eqn. and replace with a new scalarfield may be s1 , since most of the strategies used in compressibleinterfoam are same as in interfoam , can you plaese tell me what are the differences in these two.
thanks
Old   August 11, 2012, 14:55
shiv
@kyle : i tried ur method but didn't work , may be i did something work
"Assuming you declared the density field correctly, you could try this in the twoPhaseTransportProperties library,:
this part was not clear to me , please detail it a little.
thanks
Old   August 11, 2012, 20:45
Nima Samkhaniani
Hi shashank
its better you define your question better, how rho changes?
but about your question, as you said the main part of interFoam and compressilbeInterFoam are the same! however interFoam solve for constant rho and it is for incompressilbe flow, but compressibleInterFoam defines rho as function of pressure, actually it considers both phase as isothermal perfect gas which
rho=rho0+si*p and si is 1/RT ,
also check pEqn.H and alphaEqn.H to see how to consider compressibility in Equations
Old   August 12, 2012, 05:03
shiv
hi nimasam,
i am trying to implement rho=rho0+k*s1; k=constant and s1 is a volscalarfield , so i was thinking if just replacing p with s1 will do the job
Old   August 12, 2012, 16:15
Nima Samkhaniani
not exactly!
as i said before its better to compare interFoam and compressibleInterFoam to see how rho dependency to pressure has effect in equations specially in pEqn.H and alphaEqn.H
Old   April 14, 2015, 05:02
ali alkebsi
kebsiali is on a distinguished road
dear shiv
Sorry for bringing this post up from the grave
but did you succeed in implementing a variable density (for one of the phases)
if yes can you please help my showing how
my density is a function of T,P, and some other passive scalars but first i want to know how to turn it into volScalarField, what and where to make changes so everything adapts with it.
Thanks in advance
kebsiali is offline   Reply With Quote
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
varying rho in twoPhaseEulerFoam shash OpenFOAM Programming & Development 1 July 9, 2012 08:33
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
Error log vw.cfd OpenFOAM 6 August 7, 2009 05:44
Turbulence Model in interFoam some soul searching jaswi OpenFOAM Running, Solving & CFD 0 July 3, 2007 10:13
