buoyantBoussinesqSimpleFoam with porous plate problem |
May 26, 2015, 07:27 |
Rep Power: 12 |
Hi everyone,
I am building up a simple case trying to simulate the pressure drop across a porous plate, and to see if it matches with the experiment. Geometry: The geometry is simple, a duct (0.6*0.6*3) and a plate (0.6*0.6) inside of the duct. 0 folder - Initial conditions: the most important 3 parameters for setup: U: walls (fixedValue; uniform (0 0 0)); inlet (fixedValue; uniform (0.88 0 0)); outlet (zeroGradient); porous_half0/1 (cyclic) <-- generated by createBaffle T: walls and outlet (zeroGradient) inlet (fixedValue, uniform 300); porous_half0/1 (cyclic) < -- generated by createBaffle p_rgh: walls and inlet (fixedFluxPressure, uniform 0) outlet (fixedValue, uniform 0) porous_half0/1 (porousBafflePressure, cyclic, uniform 0 - jump, D = 66300, I = 100, length = 0.1) <-- generated by createBaffle So the steps I took to run the case is: blockMesh --> createBaffle -overwrite --> buoyantBoussinesqSimpleFoam I could run the case, but the residuals are not good, most of them are in between 0.01 - 1. I have played with a lot of boundary conditions, still haven't solved the convergence problem. I can reduce the inertial coefficient, which seem to converge properly except the temperature, but the results are not matching with the experiment. The inertial coefficient I calculated is based on a predicted line obtained from the experiment, the porous baffle pressure jump Delta P = - (D*mu*U + 0.5*I*rho*U^2)*L, so using a predicted line can obtain the coefficient of U and U^2, which gives the value for Darcy's coefficient and inertial coefficient. Can anyone give me some insights into this problem? |
openfoam, porous baffle interface, porous jump bc |
Problem on boundary conditions (multi-phase, porous media, 3 flow domains) | Juun | FLUENT | 1 | November 19, 2023 01:06 |
Pressure drag problem in porous media with interFoam | skp | OpenFOAM Running, Solving & CFD | 8 | May 27, 2015 08:10 |
Porous media problem in 3D | Marijo | FLUENT | 1 | March 1, 2006 17:38 |
porous media/jump mass flow problem | Marijo | FLUENT | 0 | February 17, 2006 11:49 |
POROUS SURFACE MESHING PROBLEM | subramani.j | Siemens | 1 | March 3, 2004 04:45 |
