May 26, 2014, 05:40 |
Pressure drop over packed bed is too high
Rep Power: 16 |
With the solver "twoPhaseEulerFoam" of OF version 2.3.x the pressure drop over a packed bed (inflow velocity < min. fluidization velocity) is too high. With the solver "compressibleTwoPhaseEulerFoam" of OF version 2.2.x the pressure drop was predicted correctly for inflow velocities below the min. fluidization velocity. Does anyone has an idea why? Thank you. |
April 27, 2015, 10:54 |
Dongyue Li
Rep Power: 17 |
Hello, I also acknowledge that twoPhaseEulerFoam 2.3.x predicts the different results with compressibleTwoPhaseEulerFoam.
Did u solve this problem? And is it a big difference? Best, |
August 13, 2015, 05:09 |
Ramon
Rep Power: 12 |
Same problem here. It seems the minimum fluidization velocity is calculated quite well (at least when using my settings and models), so the bending point of the delta pressure vs. velocity plots are correct, but the pressure drop itself does very strange things. It seems that the pressure drop at 0 m/s velocity is also not 0.... and the pressure drop above minimum fluidization velocity is slowly decreasing instead of stable, which suggests there is some change in the solids phase mass. I have included a picture of the OpenFOAM results, versus experimental values. Kind regards, Ramon |
How to plot pressure drop with Periodic BC? | bigfans | FLUENT | 7 | November 8, 2016 11:28 |
help in pressure drop calculation in fluent | sinaupdate | FLUENT | 3 | July 10, 2016 05:56 |
Discrepancy between the measurements (pressure drop; VOF) | blackemperor | FLUENT | 2 | March 6, 2016 03:40 |
What's meaning of pressure drop for fluid? | qihongming | Main CFD Forum | 1 | April 30, 2009 12:05 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
