interface smearing. InterFoam, OpenFOAM 2.3.0 and higher
Like Tree3Likes
  • 3 Post By ngj
Old   September 28, 2015, 11:04
Default interface smearing. InterFoam, OpenFOAM 2.3.0 and higher
Vagner Serge
vagnerserge is on a distinguished road
I have a problem with interFoam 3.1.0 and higher. I want to simulate behavior of drop under simple shear flow. So I did a domain with periodic boundary conditions, top wall and bottom wall moves in opposite direction.
If I'm using interFoam from OpenFoam 2.2.1 or 2.2.2 I have a very good results as you can see (fig 1). But if I'm using OpenFoan 2.3.0 and higher I have smearing of interface (fig 2) which is obviously not supposed to be.
Maybe someone already had this problem or I don't understand something?
fig 1 (interFoam OpenFoam-2.2.1)
fig 2 (interFoam OpenFoam-2.3.0 and higher)
Thanks in advance
Serge
Last edited by wyldckat; October 2, 2015 at 17:16. Reason: changed title from 3.1.0 to 2.3.0
vagnerserge is offline   Reply With Quote
Old   October 2, 2015, 09:51
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
If you used exactly the same input, I'd file a regression bug report with OpenCFD.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   October 2, 2015, 15:37
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo Vagner,
Could you please clarify a little bit. The title states OpenFoam 3.1 or higher, but it seems that you are only using the OpenCFD-release of OpenFoam (currently up to 2.4).
If you are really only using the OpenCFD-release, then the main difference is that OF2.2.x uses the old, explicit version of MULES, while the advection of alpha is solved implicitly with a matrix solver in OF2.3. Consequently, it could be your choice of schemes, approach for the iterations in the linear system of equations, etc. that gives rise to the smearing.
Kind regards,
Niels
Tobi, hua1015 and ashish.vinayak like this.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   April 27, 2017, 04:48
Mehdi
mehdiataei is on a distinguished road
Attachment 42377
Attachment 42378
Thanks in advance
Serge
Hi Vagner,
I am also working on a similar problem (a bubble in a shear flow). My particular focus is bubble deformation in Foam Injection Molding.
I have used Fluent up to now but I am switching to OpenFoam due to various constraints. I was wondering if you have any suggestions about implementing this problem in OpenFoam. Specifically, the type of solver, schemes, meshing and boundary conditions that gives the best result.
Also, as I am new to OpenFoam, it would be wonderful if you could share a sample case with me.
Thank you very much!
mehdiataei is offline   Reply With Quote
Old   February 4, 2019, 07:56
krishna kant
kk415 is on a distinguished road
Hello All,
Now I am curious to know the other side of the coin, if solving alpha equation explicitly with MULES reduces the smearing then why the higher versions of OF solves alpha equation by matrix and correct it by MULES. what advantage is OF 3.0 and higher over OF 2.2 ?
kk415 is offline   Reply With Quote
[OpenFOAM.org] Installation of OpenFOAM 2.3.0 on SSH RHEL 6.2 Santiago jyang1 OpenFOAM Installation 6 August 26, 2015 18:47
[Other] Mesh refinement and smooth interface shape Prosper OpenFOAM Meshing & Mesh Conversion 2 May 5, 2015 15:21
OpenFOAM v.2.x Courant Number 4 time higher then in previous versions makaveli_lcf OpenFOAM Running, Solving & CFD 8 February 18, 2012 21:28
Issues with OpenFoam sanjibdsharma OpenFOAM 0 August 14, 2009 08:41
