February 15, 2016, 05:53 |
Problems with spray simulation
Rep Power: 10 |
Hi everyone!
I'm a new user of OpenFOAM, so I'm sorry if my questions are simple. What I'm trying to do is to simulate a spray injected in a chamber with turbulent flow inside and no chemical reactions at all. I'm using sprayFoam solver. So my questions are: 1) To switch off the chemical reactions I wrote "active no" in constant/combustionProperties, but is this enough or do I need to write "chemistry off" too in constant/chemistryProperties? 2)In constant/sprayCloudProperties I have to insert T0, rho0 and Cp0, but I only know the T0 for my liquid and its injection pressure. Is there a way to make OpenFOAM calculate rho0 and Cp0 on its own? Or do I have to look for those data and insert them manually? 3)Is there a way I can extract the data about the spray penetration and timesteps from the output file and write them down somewhere else? Thank you in advance and again sorry if these are simple questions. |
engine simulation with valve motion and spray process | xianqiejiao | OpenFOAM Programming & Development | 3 | April 30, 2015 09:14 |
spray simulation | adam | CFX | 10 | June 8, 2013 15:59 |
pressure-swirl atomizer spray simulation | sjtusyc | CFX | 7 | September 27, 2012 07:43 |
spray atomization simulation and analysis | Tribikram | FLUENT | 0 | September 14, 2012 13:36 |
Problems on H2/air CFX simulation | xulixian | OpenFOAM Running, Solving & CFD | 2 | April 14, 2009 15:00 |
