multiphaseInterFoam on unstructred mesh?
Old   March 14, 2016, 06:07
Default multiphaseInterFoam on unstructred mesh?
BlnPhoenix is on a distinguished road
i set up a simple all hex test case which solved without problems. Now that i want to use multiphaseInterFoam with a more complex geometry which i generated with snappyhexmesh tough checkMesh runs just fine, the results are not satisfactory esp. the alpha values seem to be incorrect (>2 for three phases). Whats your experience with this solver, is i doomed to work only on pure hex meshes like twophaseEulerFoam?
Would be interesting to now if someone solved non hexadral problems with multiphaseInterFoam!?
Cheers
BlnPhoenix is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
