ControlDict: How to only get one time folder for the results?
Like Tree1Likes
Old   October 22, 2010, 13:19
Default ControlDict: How to only get one time folder for the results?
Daniele
Daniele111 is on a distinguished road
hi
Is possible with simpleFoam in time directory write only one data time directory? I want start my simulation from lastTime and when it finish my result must be overwrite on startTime directory, then i restar my simulation and again new result must be overwrite. I want only a directory
Thanks
Daniele111 is offline   Reply With Quote
Old   October 22, 2010, 14:23
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Daniele
Then you should consider the purgeWrite option. Its functionality is described in details in the User Guide. However, note that it requires the use of the timeStep as writeControl option.
Hope it helps and enjoy your weekend,
Niels
ngj is offline   Reply With Quote
Old   October 23, 2010, 11:37
Daniele
I tried but i have one directory for each simulation, and would only one for many simulation...
Old   October 23, 2010, 12:51
Retired Super Moderator
Bruno Santos
Greetings Danielle and Niels,
Interesting requirement Danielle, but "-overwrite" argument option only exists for meshers, AFAIK, otherwise it would be the perfect solution for you.
But you also left out one crucial piece of information: are the simulations meant to end at the same time snapshot?
For example, there are three scenarios I can think of:
  1. The simulations are meant to always end at time snapshot 1000.
  2. The simulations end at different time snapshots.
  3. The simulations end when the residuals are acceptable, therefore you end it without simpleFoam's prior knowledge. This means that you will need frequent time snapshot writes, in order to keep track of what has happened before you terminate the execution.
For either one of these, I've got a solution for you, but it depends if your system allows symbolic links in the file system. Most Linux boxes that use ext2/3/4 will do fine, but I'm not certain that for example some high end clusters will allow symbolic links...
The concept is quite simple, so here is one solution (out of N possible solutions ) for each scenario, based on the same principle:
  1. If they always end at the same time snapshot, for example 1000 - run this command in your case folder:
    ln -s 0 1000
    This will link symbolically the folder 1000 to 0, therefore anything written/read to/from folder 1000, will be in fact the folder 0.
    Then, since you don't need any time snapshots midway, you must do something like this in your controlDict:
    startFrom       startTime;
    startTime       0;
    stopAt          endTime;
    endTime         1000;
    deltaT          0.5;
    writeControl    runTime;
    writeInterval   $endTime;
    purgeWrite      0;
    Only deltaT and endTime should be different for your simulation in question! All of these other variables must be kept as they are, otherwise you wont end up with the last time snapshot saved into the desired link folder.
  2. If simulations vary in end time, then in the previous solution you only have to change the controlDict's endTime (and possibly the deltaT), and you must also create a link for that new end time, for example 900.5:
    ln -s 0 900.5
  3. If it's unknown when the simulation will be terminated, then writeInterval cannot be the same as the end time. You'll have to stipulate frequent saves, in order to keep losses to a minimum. This will be a serious pain, because you'll need one link per saved snapshot. One way to keep it simple, is to run something like this in the terminal, before each modified run (i.e., if the endTime increases or if your deltaT changes):
    endTime=0.5
    deltaT=0.1
    for t in $(seq $deltaT $deltaT $endTime | sed 's=,=\.='); do ln -s 0 $t; done
And there you have it, the solutions for the 3 scenarios I can think of. I hope I've managed to keep it simple and easy to understand. If not, I'll try to rephrase my explanations
Best regards,
Bruno
Daniel_Khazaei likes this.
Old   October 23, 2010, 13:02
Daniele
I think that my case is 3! But i try to explain better my problem. I have a evolutive simulation and I use a matlab code that execute at each time step OpenFoam to calulate wall shear stress, with new wall shear matlab calculate new domain shape and I modify mesh and restart openfoam from lastTime, the problem is that on my university server I have a limited space and the simulation are very long and I can't use a lot of space!
Old   October 23, 2010, 13:33
Bruno Santos
Hi Danielle,
Then Niels's solution should also be possible for you, as long as you:
  • Use:
    startFrom       lastTime;
    purgeWrite      1;
  • Increment the endTime for each new iteration+simulation, therefore you would have to update controlDict for each simulation.
  • In Matlab, detect which is the last time iteration, in case it ends sooner than expected (i.e., different than endTime).
Either way, you should now have more than one possible solution for your problem
Best regards,
Bruno
Old   October 23, 2010, 14:33
Daniele
"Increment the endTime for each new iteration+simulation, therefore you would have to update controlDict for each simulation."
But I don't know endTime, each OpenFoam simulation stop when residuals are down
Old   October 23, 2010, 15:08
ngj
Hi Daniele
The overall framework by Bruno is functional, and if your solver stops at a given residual, you put endTime to something really, really large. Would that work?
If your question about not knowing the endTime is a Matlab issue regarding which time folder to enter to do the post-processing step, I could imagine that you might do as follows inside matlab:
[s,w] = unix('ls -d [0-9] | sort -g | tail -1 | tr -d ''\n'''); % The ''\n'' is needed, otherwise cd(w) won't work
cd(w);
which will give you the latest time step and enter that time directory.
Best regards,
Niels
Old   October 23, 2010, 15:15
Daniele
Thanks
Doing a small summary, Would you post me an example of a controlDict file to see if i understand yours routine?
Daniele
Old   October 23, 2010, 15:22
ngj
Honestly no. Merely combine posts #6 and #8 and you should be fine.
/ Niels
Old   October 23, 2010, 15:25
Daniele
Thanks for all.
In this way Have I always only one time directory ?
Old   October 24, 2010, 05:27
Daniele
Uhmm purgeWrite don't resolve my problem...Example:
I start first simulation in OpenFoam, it converges after 47 time step and simulation stops, so I have 0 and 47 time directory. I star new simulation it starts from 47, and it converges at 56 time step, but in my case directory I don't have only 0 and 56 time directory but 0 47 and 56.
Old   October 24, 2010, 06:21
Bruno Santos
Greetings to all!
@Niels: there is a small typo in your command in post #8; it should have an asterisk for the ls:
ls -d [0-9]*
@Daniele: well in a way it's good to know that purgeWrite doesn't remove the starting snapshot, since this way we have the beginning and the end of the simulation But since this isn't what you want, I suggest what Niels has pretty much already suggested - keep using your current settings in controlDict, but run things like this:
simpleFoam
rm -rf 0
mv `ls -d [0-9]* | sort -g | tail -1 | tr -d ''\n''` 0
This will run simpleFoam, then remove the 0 snapshot when complete and move/rename the last snapshot to 0. The last two commands can be executed directly in Matlab:
unix('rm -rf 0; mv `ls -d [0-9]* | sort -g | tail -1 | tr -d ''\n''` 0')
Best regards,
Bruno
Last edited by wyldckat; October 24, 2010 at 06:37. Reason: Ooops, typo in Daniele's name...
Old   October 24, 2010, 06:25
Daniele
Thanks you a lot Bruno, now it is clear! You are very useful!
Daniele
Old   March 19, 2016, 17:38
Scram_1 is on a distinguished road
Hey,
I've already run some iterations using a custom solver. After some time (approximately 100 iterations), the Courant number starts to blow up and the simulation terminates. (At least I believe it's the Co blowing up which is causing it to terminate). Now, to ensure that the Co remains less than 1 , I want to reduce deltaT in the controlDict file. But doing so does not change the deltaT when I resume the simulation. How do I change the deltaT while ensuring that the simulation starts from the point it has stopped with the updated deltaT
Here's the error
Courant Number mean: 0.0778162 max: 1.38578
smoothSolver: Solving for Ux, Initial residual = 0.00297599, Final residual = 7.76143e-006, No Iterations 8
smoothSolver: Solving for Uy, Initial residual = 0.00559096, Final residual = 7.71217e-006, No Iterations 4
DICPCG: Solving for p, Initial residual = 0.0466867, Final residual = 9.81585e-007, No Iterations 754
DICPCG: Solving for p, Initial residual = 0.000445843, Final residual = 9.98038e-007, No Iterations 100
DICPCG: Solving for p, Initial residual = 0.000181184, Final residual = 9.64879e-007, No Iterations 53
time step continuity errors : sum local = 5.26678e-010, global = 2.18292e-015, cumulative = -3.17868e-012
DICPCG: Solving for p, Initial residual = 0.0119082, Final residual = 9.30373e-007, No Iterations 739
DICPCG: Solving for p, Initial residual = 5.90821e-005, Final residual = 9.27508e-007, No Iterations 26
DICPCG: Solving for p, Initial residual = 3.38914e-005, Final residual = 9.32952e-007, No Iterations 21
time step continuity errors : sum local = 5.04431e-010, global = 2.64054e-015, cumulative = -3.17604e-012
DILUPBiCG: Solving for T, Initial residual = 0.0122802, Final residual = 2.62996e-009, No Iterations 5
ExecutionTime = 173.687 s ClockTime = 173 s
Time = 12.1485
Courant Number mean: 0.0780047 max: 1.6609
smoothSolver: Solving for Ux, Initial residual = 0.00329476, Final residual = 4.90866e+227, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = 0.00622384, Final residual = 1.32554e+227, No Iterations 1000
DICPCG: Solving for p, Initial residual = 1, Final residual = nan, No Iterations 1001
DICPCG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1001
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 0 the word 'nan'
file: C:/OpenFOAM/cygwin64/opt/OpenFOAM/OpenFOAM-2.3.x/tutorials/incompressible/icoFoam/laminar_pipe -U=2/system/data.solverPerformance.p at line 0.
From function operator>>(Istream&, Scalar&)
in file lnInclude/Scalar.C at line 93.
FOAM exiting
And here's my controlDict file
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application my_icoFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 25;
deltaT 0.0005;
writeControl timeStep;
writeInterval 200;
purgeWrite 0;
writeFormat binary;
writePrecision 6;
writeCompression off;
timeFormat general;
maxCo 0.6;
adjustTimeStep yes;
timePrecision 6;
runTimeModifiable true;
Thanks!!
Ram
Scram_1 is offline   Reply With Quote
Old   March 20, 2016, 04:38
BlnPhoenix is on a distinguished road
adjustTimeStep is not implemented in icoFoam natively, so you can maybe try to implement it in your custom icoFoam solver for convenience. (i think i saw threads on this topic in the forum)
If you want to re-start your simulation from the latest time with adjusted time step size, you simply check the latest saved time folder (in your cases possibly 12.1 or something) open your controDict file and change the startTime to this last saved time step, where your simulation converged. Don't forget to adjust the time step also.
But as i mentioned adjustable run time is the more convinient way to cope with increasing courant numbers.
Have fun.
BlnPhoenix is offline   Reply With Quote
Old   March 21, 2016, 11:47
Hey BlnPhoenix,
I tried doing what you'd suggested but its not working...This is what I tried.
This is my custom solver. And I used setDeltaT in the hope that it will read the deltaT from the controlDict file.
#include "fvCFD.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
#include "createFields.H"
#include "initContinuityErrs.H"
Info<< "\nStarting time loop\n" << endl;
while (runTime.run())
Info<< "Time = " << runTime.timeName() << nl << endl;
#include "readPISOControls.H"
#include "readTimeControls.H"
#include "CourantNo.H"
#include "setDeltaT.H"
runTime() ++;
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
solve(UEqn == -fvc::grad(p));
// --- PISO loop
for (int corr=0; corr<nCorr; corr++)
volScalarField rAU(1.0/UEqn.A());
volVectorField HbyA("HbyA", U);
HbyA = rAU*UEqn.H();
surfaceScalarField phiHbyA
"phiHbyA",
(fvc::interpolate(HbyA) & mesh.Sf())
+ fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
adjustPhi(phiHbyA, U, p);
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
if (nonOrth == nNonOrthCorr)
phi = phiHbyA - pEqn.flux();
#include "continuityErrs.H"
U = HbyA - rAU*fvc::grad(p);
U.correctBoundaryConditions();
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
TEqn.solve();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
Now here's what I get when I run the solver for my case
Time = 12.15578
Courant Number mean: 0.0111567 max: 0.511585
deltaT = 6.45436e-005
smoothSolver: Solving for Ux, Initial residual = 0.00180382, Final residual = 6.162e-007, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.00295248, Final residual = 2.7079e-007, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0164652, Final residual = 9.7402e-007, No Iterations 732
DICPCG: Solving for p, Initial residual = 4.28776e-005, Final residual = 8.91207e-007, No Iterations 12
DICPCG: Solving for p, Initial residual = 1.30543e-005, Final residual = 8.37702e-007, No Iterations 5
time step continuity errors : sum local = 5.25956e-011, global = 1.0707e-015, cumulative = 6.64415e-011
DICPCG: Solving for p, Initial residual = 0.000841824, Final residual = 9.98842e-007, No Iterations 450
DICPCG: Solving for p, Initial residual = 4.01403e-006, Final residual = 9.26023e-007, No Iterations 10
DICPCG: Solving for p, Initial residual = 2.30103e-006, Final residual = 8.52151e-007, No Iterations 2
time step continuity errors : sum local = 5.35375e-011, global = -3.18539e-012, cumulative = 6.32561e-011
DILUPBiCG: Solving for T, Initial residual = 0.00547638, Final residual = 1.73926e-009, No Iterations 3
ExecutionTime = 839.743 s ClockTime = 840 s
Time = 12.15584
Courant Number mean: 0.0109212 max: 0.510881
deltaT = 6.3169e-005
smoothSolver: Solving for Ux, Initial residual = 0.00179596, Final residual = 5.92427e-007, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.00296089, Final residual = 2.65592e-007, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0179838, Final residual = 9.62282e-007, No Iterations 731
DICPCG: Solving for p, Initial residual = 3.90246e-005, Final residual = 8.9584e-007, No Iterations 12
DICPCG: Solving for p, Initial residual = 1.18486e-005, Final residual = 8.32487e-007, No Iterations 5
time step continuity errors : sum local = 5.14033e-011, global = -3.29354e-015, cumulative = 6.32529e-011
The Co is no longer blowing up. But the time is not advancing by the step given in the controlDict. If I let the solver solve for some more time, the significant digits in the time reach an absurdly large 8-10 (for example the time shown in the command terminal becomes 12.16543879...). I want the time to advance by the deltaT mentioned in the controlDict.
Any help is greatly appreciated.
Thanks!!
Ram
Old   March 21, 2016, 12:03
so the time in the terminal 12.16543879 would mean that your time step size gets smaller and smaller i suppose. This on the other hand would mean that you have implentend an adjustable time step into the solver. Unfortunatly i have no experience with custom solvers so i cannot say whether the error may be in the implementation into your custom icoFoam solver or in the problem itself (boundary conditions etc.) (
So yea, can you please check that you have set your controlDict to
adjustTimeStep no;
and
if u want a fixed time step for your simulation?!
Maybe someone else can be of more help. Good luck.
Old   March 21, 2016, 16:17
Hey BlnPhoenix,
Thanks for your reply. I changed the write control to timeStep and tried again. Now the solver is giving a warning regarding timePrecision. This is what it says
Time = 12.1401
Courant Number mean: 0.00768437 max: 0.0709925
--> FOAM Warning :
From function Time:perator++()
in file db/Time/Time.C at line 1055
Increased the timePrecision from 6 to 18 to distinguish between timeNames at time 12.1401
smoothSolver: Solving for Ux, Initial residual = 0.000179277, Final residual = 9.51591e-009, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.000461942, Final residual = 1.47774e-008, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.0460253, Final residual = 9.43666e-007, No Iterations 734
DICPCG: Solving for p, Initial residual = 0.00357939, Final residual = 9.96147e-007, No Iterations 315
DICPCG: Solving for p, Initial residual = 0.00136696, Final residual = 9.94625e-007, No Iterations 131
time step continuity errors : sum local = 1.01988e-011, global = -1.34098e-013, cumulative = -1.31505e-013
DICPCG: Solving for p, Initial residual = 0.000789953, Final residual = 9.43314e-007, No Iterations 312
DICPCG: Solving for p, Initial residual = 0.000349991, Final residual = 9.73125e-007, No Iterations 57
DICPCG: Solving for p, Initial residual = 0.000195612, Final residual = 9.82302e-007, No Iterations 76
time step continuity errors : sum local = 1.00649e-011, global = -1.88417e-013, cumulative = -3.19922e-013
DILUPBiCG: Solving for T, Initial residual = 0.000736939, Final residual = 1.67772e-008, No Iterations 1
ExecutionTime = 30.088 s ClockTime = 30 s
Time = 12.1401000000000003
Courant Number mean: 0.00768449 max: 0.0717468
smoothSolver: Solving for Ux, Initial residual = 0.000172211, Final residual = 8.9619e-009, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.000430594, Final residual = 1.20743e-008, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.0289387, Final residual = 9.32201e-007, No Iterations 725
It proceeds but the time precision is now 18!! I'm attaching my solver code and Boundary conditions file as well. The case is a simple laminar flow through a pipe. If someone can figure out why this is happening it'll be of great help!
Solver: myicoFoam.C
\\ / O peration |
\\ / A nd | Copyright (C) 2011-2013 OpenFOAM Foundation
\\/ M anipulation |
License
This file is part of OpenFOAM.
OpenFOAM is free software: you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received a copy of the GNU General Public License
along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>.
Application
icoFoam
Description
Transient solver for incompressible, laminar flow of Newtonian fluids.
#include "fvCFD.H"
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
// --- PISO loop
"phiHbyA",
fvScalarMatrix pEqn
pEqn.solve();
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
TEqn.solve();
runTime.write();
<< nl << endl;
return 0;
controlDict:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application myicoFoam;
startTime 0;
stopAt endTime;
endTime 25;
deltaT 0.00005;
writeInterval 200;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
maxCo 0.6;
adjustTimeStep no;
timePrecision 6;
O folder
P:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
INLET
type zeroGradient;
OUTLET
type fixedValue;
value uniform 0;
TOP_WALL_STRAIGHT
type zeroGradient;
BOTTOM_WALL_STRAIGHT
type zeroGradient;
BOTTOM_WALL_WAVY
type zeroGradient;
TOP_WALL_WAVY
type zeroGradient;
frontAndBackPlanes
type empty;
T:
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
INLET
type fixedValue;
value uniform 300;
OUTLET
type zeroGradient;
TOP_WALL_STRAIGHT
type fixedValue;
value uniform 330;
type fixedValue;
value uniform 330;
BOTTOM_WALL_WAVY
type fixedValue;
value uniform 330;
TOP_WALL_WAVY
type fixedValue;
value uniform 330;
frontAndBackPlanes
type empty;
U:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (2 0 0);
boundaryField
INLET
type fixedValue;
value uniform (2 0 0);
OUTLET
type zeroGradient;
TOP_WALL_STRAIGHT
type fixedValue;
value uniform (0 0 0);
type fixedValue;
BOTTOM_WALL_WAVY
type fixedValue;
TOP_WALL_WAVY
type fixedValue;
frontAndBackPlanes
type empty;
Old   March 21, 2016, 16:23
I tried removing timePrecision and maxCo from the controlDict file but still its changing the precision to 18 and proceeding. Thought this might help...
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
