nut, k, omega wall condition with k omega SST |
April 2, 2016, 10:09 |
Rep Power: 10 |
Hi guys, i would like to understand if my assumptions are corrected. I have a mesh of an airfoil with y+ around wall <1. I want use k omega SST. This model considers flux turbulent fully developed, so i want to understand if i have to consider the flux like was in y+> 30 and then use wall functions?
April 2, 2016, 12:47 |
#2 | |
Rep Power: 10 |
hi guys, i have a mesh with y+<1 a i use k omega SST. How you valutate this BC on wall? K_wall=1e-12 omega_wall=1e+7 according this post:
Last edited by wyldckat; April 2, 2016 at 18:37. Reason: Added missing QUOTE markers |
April 3, 2016, 04:29 |
Alex
Rep Power: 12 |
You can use a very small, non-zero fixedvalue for k, omegawallfunction for omega and nutlowrewallfunction for nut. These are my preferred lowRe mesh wall BCs for the variables.
April 3, 2016, 10:59 |
Rep Power: 10 |
I've set nut to calculated. And I have a doubt if my fvschemes and fvsolution are correct:
Fv schemes ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Fv solution solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.1; } k { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } omega { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p 1e-5; U 1e-5; k 1e-5; omega 1e-5; } } relaxationFactors { fields { p 0.3; } equations { U 0.3; k 0.3; omega 0.3; } } |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 11:30 |
wall boundary condition for k-w SST model | Joachim | Main CFD Forum | 2 | April 17, 2014 08:53 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
Boundary Conditions for k omega SST | dancfd | OpenFOAM Pre-Processing | 0 | June 9, 2011 23:25 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
