How to run in parallel with using dynamicRefineFvMesh |
April 21, 2016, 09:58 |
Li Linmin
Rep Power: 10 |
Dears,
I am now working with dynamic refine mesh method. But I found that if I use the dynamic refine mesh method and run in parallel. But I cannot reconstruct and it comes the error: cannot find file. Anyone can help me? Linmin |
April 22, 2016, 14:27 |
Rep Power: 20 |
You probably need to reconstruct the mesh with reconstructParMesh before running
reconstructPar since your mesh has changed. |
April 23, 2016, 07:05 |
Li Linmin
Rep Power: 10 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 12:40 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 14:43 |
Run in parallel a 2mesh case | cosimobianchini | OpenFOAM Running, Solving & CFD | 2 | January 11, 2007 06:33 |
