Setting the pressure outlet based on massflowrate at birfucation artery |
May 23, 2016, 07:41 |
hisham
Rep Power: 10 |
Hi foamers,
I have a task which ask me to simulate the flow in an artery bifurcation (one inlet-two outlets). Currently Im used icofoam to solve this problem. For pressure outlet1 I set as zero and I want to control the pressure outlet2 using this equation P2=P1+deltaP where my deltaP = k*Qin*(Qout1-Qmeasure)/(density*area1*area1). I hv used function object to calculate the Qin, Qout1 and Qout2. but the problem is I can`t call this function to solve my equations. I didn`t know how to set it. Here also I attached my U, p and controlDict file as references. Hopefully somebody can help me and give an idea how can I solve this problems.. Hisham |
May 23, 2016, 22:12 |
hisham
Rep Power: 10 |
Nobody can help me?
September 7, 2016, 11:43 |
Rudolf Hellmuth
Could you find out the solution for that. I am facing more or less the same problem. Not sure how to set the BCs.
In my case I know the inlet velocity, and I would like to outlet0 to have about 5% of the inlet flow rate and outlet1 to have 95%. It doesn't necessarily have to be exactly 5 to 95%, other solutions would also be welcomed. Basically, the flow resistance on outlet0 is much higher than on outlet1. Scheme: Code:
/=== --> outlet0: ~5% flow rate // inlet --> =======<< \\ // /================ --> outlet1: ~95% flow rate Rudolf |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
interFoam (HELYX-OS) pressure boundary conditions | SFr | OpenFOAM Running, Solving & CFD | 8 | June 23, 2016 16:36 |
Using pressure outlet BC | Shreyansh | FLUENT | 0 | November 5, 2010 14:57 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
