October 10, 2016, 20:41 |
Parallel
alberto
Rep Power: 10 |
HELLO
I am trying to simulate flow around a circle with this comand mpirun -np 4 icoFoam -parallel the simulation start to run but latter stops Time = 0.02351 Courant Number mean: 0.0126132 max: 0.0617498 DILUPBiCG: Solving for Ux, Initial residual = 5.44938e-05, Final residual = 4.9505e-07, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.000153462, Final residual = 4.18194e-08, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.000337653, Final residual = 9.25326e-07, No Iterations 282 DICPCG: Solving for p, Initial residual = 9.25254e-07, Final residual = 9.25254e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 9.25254e-07, Final residual = 9.25254e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 9.25254e-07, Final residual = 9.25254e-07, No Iterations 0 time step continuity errors : sum local = 2.1549e-13, global = 6.66153e-21, cumulative = -9.90915e-18 DICPCG: Solving for p, Initial residual = 5.17707e-05, Final residual = 9.95583e-07, No Iterations 171 DICPCG: Solving for p, Initial residual = 9.95579e-07, Final residual = 9.95579e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 9.95579e-07, Final residual = 9.95579e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 9.95579e-07, Final residual = 9.95579e-07, No Iterations 0 time step continuity errors : sum local = 2.65615e-13, global = 6.942e-21, cumulative = -9.90221e-18 ExecutionTime = 633.61 s ClockTime = 677 s Time = 0.02352 Courant Number mean: 0.0126133 max: 0.0617514 DILUPBiCG: Solving for Ux, Initial residual = 5.44876e-05, Final residual = 4.99864e-07, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.000153441, Final residual = 4.18107e-08, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.000403103, Final residual = 9.71958e-07, No Iterations 155 DICPCG: Solving for p, Initial residual = 9.71865e-07, Final residual = 9.71865e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 9.71865e-07, Final residual = 9.71865e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 9.71865e-07, Final residual = 9.71865e-07, No Iterations 0 time step continuity errors : sum local = 2.51466e-13, global = 2.84372e-21, cumulative = -9.89936e-18 dui@dui-P45VA:~/Documentos/openfoam/Re95$ reconstructPar /*--------------------------------------------------------- in some time, the simulation stop but without finish, stop at 0.02352 , and i set in mi controldict at 1.75. when i run normally takes 17 hours, so i am trying with parallel but the simulation stop. Help please! someone can help me. |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
