simpleFoam - setting the pref value
Old   November 6, 2016, 06:38
Default simpleFoam - setting the pref value
Giles Richardson
ufocfd is on a distinguished road
I have been running simpleFoam for flow analysis over a car and initially set pref = 101325 (in the fvSolution file) which was giving quite large forces when integrating the surface pressure over a car body.
I then changed pref=0 and re-ran the same case, giving significantly lower force values (and more realistic CL & CD), when integrating the surface pressure on vehicle.
Think it maybe be related to the surface pressure integration method in Paraview.
ufocfd is offline   Reply With Quote
Old   November 9, 2016, 13:34
Mahdi Hosseinali
anishtain4 is on a distinguished road
When you're solving incompressible flow the absolute pressure is not important, it's just the gradient (even when integrating an immersed surface such as a car body). If your solutions are correct velocity profiles should be reasonable.
anishtain4 is offline   Reply With Quote
prefcell/prefvalue, simplefoam
SimpleFoam setting with total pressure at inlet dmaz OpenFOAM Running, Solving & CFD 2 June 24, 2016 10:17
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
