[Sponsors] | |||||
Shuai Yuan
Rep Power: 11 ![]() |
Hey everyone,
When I am running a sprayfoam case in supercomputer, I met the following error. Could anyone tell me the reason? --> FOAM FATAL IO ERROR: error in IOstream "/general/home/sy2516/Aerosol/aerosolcase2/0.00465/PaSR:kappa" for operation Ostream& operator<<(Ostream&, const UList&) file: /general/home/sy2516/Aerosol/aerosolcase2/0.00465/PaSR:kappa at line 22. From function bool Foam::IOstream::check(const char *) const in file db/IOstreams/IOstreams/IOstream.C at line 96. FOAM exiting |
There could be lots of reasons and it would be easier to get an answer if you ask supercomputer administrators. There are several guesses: 1. Disk space quota limit. You hit the limit, you can not write to the disk. 2. FS idiosyncrasies. If it is the first output, then MAYBE your network file system does not like : in file names. |
#3 | |
Shuai Yuan
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
| OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. | MBttR | OpenFOAM Running, Solving & CFD | 0 | June 13, 2016 11:58 |
| OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 04:18 |
| Difficulty running an inviscid compressible nozzle flow using OpenFOAM | rbozinoski | OpenFOAM Running, Solving & CFD | 11 | December 29, 2015 08:19 |
| Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 10:38 |
