April 4, 2017, 13:43 |
outlet boundary condition
Ali
Rep Power: 14 |
Hello everyone,
I have a geometry with 1 inlet and 3 outlets which each has a portion of flowrate goes out from them. I used outflow option in Fluent to do the simulation which works fine. Tried to do the similar thing in openfoam using flowrateInletVelocity by pre-calculating the out flow, however, since I might get some back flows at first few iterations it doesnt go through and after a few iteration the courant number just blows up! So, my question is, I guess, is there anyway that I can combine outletInlet and flowRateInletVelocity? If not, any other suggestion would be highly appreciated. Thanks Ali |
April 5, 2017, 17:14 |
Santiago Lopez Castano
Rep Power: 15 |
Have you tried 'advective' boundary condition? This is a condition that guarantees no backscatter
Sent from my GT-I8190L using CFD Online Forum mobile app |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
volumetric flow rate is fluctuating in outlet boundary condition location | oozcan | FLUENT | 1 | November 30, 2016 03:00 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
