error when running movingConeTopoFvMesh in parallel |
May 15, 2017, 11:20 |
Rep Power: 9 |
Hello everyone, I'm modeling a rigid body moving through a tube. I modified the movingConeTopoFvMesh.
By using a single processor, the code works well. But once I run the it in parallel, I met the following error: [28] --> FOAM FATAL ERROR: [28] in patchrocBoundary28to19 : Local size of patch is 4 (faces). Received from neighbour 3 faceCentres! [28] [28] From function virtual bool Foam:rocessorPolyPatch:rder(Foam::PstreamBuffe rs&, const primitivePatch&, Foam::labelList&, Foam::labelList&) const [28] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 922. [28] FOAM parallel run aborting Anyone knows how to solve this problem? Should I update the procBoundaries in each step? How should I do it? Thank you so much. |
movingconetopofvmesh, topochangerfvmesh |
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 21:33 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 07:02 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 03:50 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
