June 14, 2017, 08:07 |
particle collector function in OpenFOAM
Evangelos Antoniou
Rep Power: 9 |
Hi Foamers,
Did you know how to use particle collector function in OF? I would like to measure how many particles are concentrate in a specific patch. Thanks in advance and best regards, Evangelos |
January 14, 2018, 11:20 |
Asmaa
Rep Power: 10 |
Hi Vaganto,
Did you get a response to this question? Asmaa |
May 10, 2019, 04:12 |
Mustafa
Rep Power: 10 |
Hey Vaganto,
As described, particleCollector gathers summed up lagrangian data (mass and mass flow rate) through a region defined by the user. Code:
particleCollector1 { type particleCollector; mode concentricCircle; origin (0.05 0.025 0.005); radius (0.01 0.025 0.05); nSector 10; refDir (1 0 0); normal (0 0 1); } The output is stored in any the VTK folders that you generate, within each time step. There may be a PyFOAM script to plot these, I'm not entirely sure Code:
particleCollector1 { massTotal 30 { 0 }; massFlowRate 30 { 0 }; } Best, Mustafa |
particle number concentration in OpenFOAM | wentao | OpenFOAM Programming & Development | 47 | March 20, 2022 23:43 |
OpenFoam Lagrange Volume Fraction & Particle Size | DustExplosion | OpenFOAM | 0 | December 6, 2016 13:11 |
OPENFOAM vs CFX for particle agglomeration | Amir1 | Main CFD Forum | 0 | May 21, 2013 19:20 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
