July 15, 2020, 07:42 |
How to find the Nusselt number along a wall?
Alex
Rep Power: 7 |
I am running a case of Natural convection heat transfer between a hot vertical plate and the atmosphere.
I am using buoyantBoussinesqPimpleFoam, it is a laminar case, so the Grashof number is laminar and the turbulenceProperties are set to "laminar", so there is no RAS turbulence model. I would like to find the value of the Nusselt Number along the wall, but in the previous discussion I did not find anything that could fit for my case. My programming skills are quite limited so I kindly ask you to give me a sort of step by step explanation if you have some ideas. Thanks for the help |
nusselt calculation, nusselt number |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
how to find nusselt number at stagnation point for jet impingment | waqarha2003 | Main CFD Forum | 0 | February 7, 2018 10:37 |
need help to find nusselt number | waqarha2003 | FLUENT | 1 | February 7, 2018 10:03 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
