Continuity error cannot be removed by adjusting the outflow - rotating domain case |
July 7, 2017, 06:06 |
Thomas Sprich
Rep Power: 11 |
Dear Forum,
I am receiving the above mentioned error for the case I am trying to run. The full error message is as follows: Code:
--> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 1516.5 Specified mass inflow : 0.0007348 Specified mass outflow : 0.00057401 Adjustable mass outflow : 0 From function bool Foam::adjustPhi(Foam::surfaceScalarField&, const volVectorField&, Foam::volScalarField&) in file cfdTools/general/adjustPhi/adjustPhi.C at line 107. FOAM exiting I have seen the following post: Continuity error cannot be removed by adjusting the outflow. Please check the velocit which discusses this problem, noting that it could be a problem with my boundary conditions. I am assuming that the problem is with my U and p files. These files are as follows: U Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { rotorBottom { type movingWallVelocity; value uniform (0 0 0); } AMIbottom { type cyclicAMI; value uniform (0 0 0); } AMIbottom_slave { type cyclicAMI; value uniform (0 0 0); } baffles { type fixedValue; value uniform (0 0 0); } tank { type fixedValue; value uniform (0 0 0); } shaft { type fixedValue; value uniform (0 0 0); } bottomOfTank { type fixedValue; value uniform (0 0 0); } topOfTank { type fixedValue; value uniform (0 0 0); } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { rotorBottom { type zeroGradient; } AMIbottom { type cyclicAMI; value uniform 0; } AMIbottom_slave { type cyclicAMI; value uniform 0; } baffles { type zeroGradient; } tank { type zeroGradient; } shaft { type zeroGradient; } bottomOfTank { type zeroGradient; } topOfTank { type zeroGradient; } } I have tried running potentialFoam as suggested but it doesn't resolve the error. In desperation, I have also checked that the rotational axis is correct, I have remeshed to get better agreement between the slave a master AMI patches, I have remeshed using different methods (meshing the whole stator and rotor domains in one operation and again meshing the stator and rotor separately and using mergeMesh). I have run moveDynamicMesh and it runs correctly. I am using the fvSolution and fvSchemes from the propeller case. I have just tried changing the speed of rotation in dynamicMeshDict. I found that if I made it very big, the mass inflow and outflow values increase in the error message above. If I decrease omega so that it is very small, the mass inflow and outflow values also decrease. This makes me think that the error might due to the rotating domain or perhaps the AMI interface between slave and master patches. Is there anyway that I could troubleshoot this? The part of the sHM dict that creates the AMI patches and rotating zone looks as follows: Code:
AMIbottom { level (2 2); faceType baffle; cellZone rotatingDomainBottom; faceZone rotatingDomainBottom; cellZoneInside inside; } Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 8 ( AMIbottom { type cyclicAMI; inGroups 1(cyclicAMI); nFaces 51672; startFace 5977891; transform noOrdering; neighbourPatch AMIbottom_slave; } AMIbottom_slave { type cyclicAMI; inGroups 1(cyclicAMI); nFaces 51672; startFace 6029563; transform noOrdering; neighbourPatch AMIbottom; } rotorBottom { type wall; inGroups 1(wall); nFaces 30099; startFace 6081235; } baffles { type wall; inGroups 1(wall); nFaces 32160; startFace 6111334; } tank { type wall; inGroups 1(wall); nFaces 87354; startFace 6143494; } shaft { type wall; inGroups 1(wall); nFaces 7779; startFace 6230848; } bottomOfTank { type wall; inGroups 1(wall); nFaces 24822; startFace 6238627; } topOfTank { type wall; inGroups 1(wall); nFaces 24910; startFace 6263449; } ) // ************************************************************************* // Thanks, Thomas |
July 9, 2017, 14:46 |
sandy
Rep Power: 10 |
i have recieved this error and i have solved it:
one thing i can promise you is ; error is in your boundary conditions. just be 100% sure of that. other thing is: this error pops up when you solve same problem in different openfoam versions. mainly bcz codes evolve overtime. so adjust your boundary conditions. problem is most likely to be in P/U files. have luck! |
July 10, 2017, 01:55 |
Thomas Sprich
Rep Power: 11 |
Hi Saddy,
Thanks for your input. Do you have any suggestions regarding the U and P BCs? To me they look right but I have been staring at it for days and can't figure it out. Thanks again, Thomas |
July 10, 2017, 05:17 |
Thomas Sprich
Rep Power: 11 |
Greetings Saddy and the rest of the Forum,
I resolved the problem. Thanks for the help. As Saddy mentioned and the error message mentioned the problem was my boundary conditions for U. The exists in both the stationary and rotating regions of the domains, but I had a 'fixedValue' boundary condition. By changing it to 'movingWallVelocity' as is the case with the rotor, the problem is resolved. I'm not sure if this is a valid boundary condition for the part of the shaft in stationary region so I may remove the shaft altogether or create separate shaft patches in the stationary and rotating domains. Problem solved. Whew. Thomas |
July 10, 2017, 08:36 |
sandy
Rep Power: 10 |
whoa.......i was just here looking for the problem and in 1 second you solved it!! bravo
yeah i figured this same reason, actually physically we have to imagine whether we are unnecessarily imposing fixed/moving condition to one of our boundaries. this type of boundary conditions sometimes lead to divergence later or solution wont proceed at all. anyways u got it! |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
