No flow rate in outlet with advective velocity
Old   July 19, 2017, 04:34
Default No flow rate in outlet with advective velocity
Robert Castilla
rcastilla is on a distinguished road
I am working in a project with rhoCentralFoam. It is transonic-supersonic flow with two inlets and one outlet. In order to avoid wave reflections, I have defined the boundary condition for pressure in outlet as waveTransmissive. The problem is that if a define the velocity as advective, I get no flow rate in outlet. Velocity is zero. I know that it should be the normal behaviour when there is a backflow (negative flux), but I dont know why it should be so. Inside the domain the pressure is higher than atmosphere, and in the waveTrasmissive the fieldInf is defined as 1 atm. I have no clue what can be the problem.
The definition in oultet for pressure:
type waveTransmissive;
value uniform 101300; //important for correct I/O
field p; //the name of the field that we are working on
gamma 1.4; //the ratio of specific heats
phi phi; //the name of the volumetric flux field ( or if you use the mass flux phi, it will be divided by rho)
rho rho; //the name of the density field
psi thermosi; //the name of the field that is the deriv. of density with respect to pressure
lInf 10; //a measure of how far away the far-field condition should be
fieldInf 101300; //the far-field value to be applied to p
and for velocity:
type advective;
phi phi;
With this definition, the behaviour is like a wall.
If I put inletOutlet for velocity in outlet, it seems to work fine.
With best regards
Robert
rcastilla is offline   Reply With Quote
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
DPM total mass flow rate yow FLUENT 0 July 17, 2015 12:01
difference between inlet and outlet flow rate ?? vitorspadetoventurin OpenFOAM Running, Solving & CFD 0 November 22, 2014 20:49
changing velocity (outlet) BC to pressure outlet majid_kamyab FLUENT 7 October 22, 2014 11:50
Volume flow rate boundary condition in OpenFOAM mayank.dce2k7 OpenFOAM Running, Solving & CFD 13 August 11, 2014 20:16
