Changing writeInterval on the fly doesn work in parallel runs |
August 10, 2014, 16:48 |
anonymous
Rep Power: 12 |
I'm using OF210 and I implemented an automatic change the writeInterval depending on the time of the simulation. Here is the implementation in the solver : Code:
int main(){ ... IOdictionary controlDict(IOobject("controlDict", runTime.system(),mesh,IOobject::MUST_READ,IOobject ::AUTO_WRITE)); ... while (runTime.loop()){ ... if(runTime.value()>=0.05){ Info<<"I enter"<<endl; controlDict.set("writeInterval",0.05); controlDict.Foam::regIOobject::write(); } ... } } But once I make a parallel run, the controlDict which is in every /case/processor*/system/ changes, but the one in the case/system/ doesn't change, and I don't know why, but he uses the writeInterval which is in the main case folder. Here is my controlDict: Code:
startFrom startTime; startTime 0; stopAt endTime; endTime 700; deltaT 0.0005; writeControl adjustableRunTime; writeInterval 0.01; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; maxCo 0.7; adjustTimeStep yes; // Or no maxDeltaT 1; Thank you very much. |
March 16, 2016, 05:06 |
Brugiere Olivier
Rep Power: 17 |
Hello everyone,
I have the same problem with version OF240. Does someone has an idea to fixe the problem? thank you in advance |
September 25, 2017, 14:22 |
Rep Power: 10 |
Hi, Have you solve this problem? I have this problem too recently and don't have a solution. Thanks.
September 26, 2017, 00:43 |
Uwe Pilz
Rep Power: 15 |
It may be that that doesn't work. In parallel, the calculating task has to be splitted into tasks for each processor. Changing the control dict would lead to a compilation of the result so far an a new splitting. I don't think that this is implemented.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
September 26, 2017, 03:01 |
Rep Power: 10 |
Thanks. I found another soluting using the timeactivatedfileupdate function object to copy and replace the controlDict reaching a specified time. It works great for serial simulations. But for parallel simulations, it only regIOobject for the first time. The controlDict is replaced after that but the changes are not updated. Very strange. I am using OpenFoam 3.0.
RBF motion solver does not work well in parallel | lakeat | OpenFOAM Bugs | 3 | August 8, 2013 05:50 |
Could SU2_V2.0.2 work properly with continuous_adjoint.py script in parallel mode? | Tommy Chen | SU2 Shape Design | 1 | April 18, 2013 13:06 |
LTSReactingParcelFoam doesn't work in parallel | Chrisi1984 | OpenFOAM Running, Solving & CFD | 4 | August 6, 2012 03:08 |
OpenFOAM 2.0.0. and 2.0.1 doesn't work in parallel mode | rv82 | OpenFOAM Running, Solving & CFD | 3 | October 3, 2011 10:47 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
