reactingTwoPhaseEulerFoam for modelling wall boiling flows
Like Tree2Likes
  • 2 Post By Sid!
Old   September 26, 2017, 05:57
Default reactingTwoPhaseEulerFoam for modelling wall boiling flows
Siddharth
Sid! is on a distinguished road
Hi Foamers,
I am using the reactingTwoPhaseEulerFoam solver in OpenFOAM v1612+ to simulate boiling of water in a pipe.
The geometry is a horizontal pipe of 4 m length and 15.4 mm diameter. I simulate only half of the pipe, so one of the boundary is a symmetry plane and the other boundary is a heated wall. I simulated single phase flow of water in the pipe and used the velocity, k, epsilon and nut at the outlet as the inlet for my multiphase simulation. The inlet velocity for the single phase simulation is 1 m/s and pressure is 45 bar. The geometry and the mesh in the single phase and multiphase simulations are the same.
In the multiphase simulation, the heat flux at the wall is 5.7e5 W/m2. Chemistry and combustion are switched off. Turbulence for both phases is modelled using k epsilon model.
The multiphase simulations run without any complaints but the temperature and the pressure increases above the prescribed saturation values and no vapour is formed. I am unsure as to if my pressure boundary condition and the phase properties are correct. I would appreciate if someone could have a look at them and let me know if anything is incorrect.
For reference I have attached the p, p_rgh and thermophysical properties file. The thermodynamic and transport properties correspond to 45 bar. I have used the prghPressure boundary condition at the exit and estimated the pressure drop to be about 0.3 bar. Hence the outlet pressure is 44.7 bar. Please let me know if this boundary condition is correct.
I have also attached the checkMesh log file, phase properties, fvSchemes and fvSoution file.
On a side note, has anyone managed to simulate the Bartolomej boiling experiment using either the twoPhaseEulerFoam or the reactingTwoPhaseEulerFoam solver?
Sorry for the long post. I would appreciate if anyone could help me with my simulations. If my question is unclear or if any further information is needed, kindly let me know in the comments.
Regards,
Sid
*--------------------------------*- C++ -*----------------------------------*\
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 4470000;
boundaryField
    inlet
        type            calculated;
        value           $internalField;
    outlet
        type            calculated;
    symmetry
        type            symmetryPlane;
    heatedWall
        type            calculated;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    location    "5";
    object      p_rgh;
boundaryField
    inlet
        type            fixedFluxPressure;
    outlet
        type            prghPressure; //prghPressure;
        //value		uniform 0;
	p               uniform 4470000;
        value           uniform 4470000;
    symmetry
        type            symmetryPlane;
    heatedWall
        type            zeroGradient;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties.liquid;
thermoType
    type            heRhoThermo;
    mixture         multiComponentMixture;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie          specie;
    energy          sensibleEnthalpy;
dpdt no;
species
    water
inertSpecie water;
"(mixture|H2O|water)"
    specie
        nMoles          1;
        molWeight       18.0153;
    equationOfState // rho = rho(T)
	rhoCoeffs<8>	( 1513.93 -1.3688 0 0 0 0 0 0 ); // rho = a + bT
    thermodynamics
        Sf		0;
        Hf              0;
	Tref        	530.59;
        Href        	1122200;
	CpCoeffs<8>     ( 654.38 8.1036 0 0 0 0 0 0 ); // Cp = a + bT
    transport
        muCoeffs<8>     ( 4.053e-4 -5.702e-7 0 0 0 0 0 0 );  // mu = a + bT
	kappaCoeffs<8>  ( 1.0967 -9.1269e-4 0 0 0 0 0 0);  // kappa = a + bT
	Pr          	0.8304;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      thermophysicalProperties.gas;
thermoType
    type            heRhoThermo;
    transport       const;
    thermo          hRefConst;
    equationOfState rhoConst;
    specie          specie;
dpdt no;
species
    water
inertSpecie water;
chemistryReader foamChemistryReader;
foamChemistryFile "$FOAM_CASE/constant/reactions.gas";
water
    specie
        nMoles          1;
        molWeight       18.0153;
    equationOfState
        R	   1695;
	rho        22.697;
    thermodynamics
        Hf          0;
        Cp          4227;
        Tref        530.59;
        Href        2797900;
    transport
        mu          1.7777e-5;
        Pr          1.4099;
arvindpj and ZZW like this.
Sid! is offline   Reply With Quote
Old   October 20, 2017, 10:40
hinmanws is on a distinguished road
I am having a similar issue with reactingTwoPhaseEulerFoam.
Were you able to resolve this?
hinmanws is offline   Reply With Quote
Old   October 24, 2017, 01:24
Siddharth
I am still working on it.
Are you simulating the same case?
Old   July 4, 2018, 02:43
Richard
Qinh is on a distinguished road
Hello Siddharth,
This thread is almost one year ago. Could you please tell me how did you solve this problem finally? Thank you in advance!
Best regards!
Qinhao
Qinh is offline   Reply With Quote
Old   July 4, 2018, 03:45
Siddharth
Hi Qinh,
I managed to solve the problem. Since I was performing an axis-symmetric simulation of flow in a pipe, I had to use the wedge boundary condition. This improved the simulation results.
Old   July 4, 2018, 20:27
Richard
Hello Siddharth,
Thank you for your quick reply. By the way, what does the "div\(\(\(\(alpha.*\*thermo:rho.*\)\*nuEff.*)\*dev 2\(T\(grad\(U.*\)\)\)" mean in the fvSchemes in the reactingTwoPhaseEulerFoam? It can not be set as Gauss upwind or Gauss limitedLinear but Gauss linear. I am puzzled about it, could you please give some hints?
Best regards,
Qinhao
Old   September 8, 2018, 10:01
Default Flow boiling
Ram Kumar Pal
rampal is on a distinguished road
Dear friends, I'm doing the same problem in Ansys Fluent. But I am not getting the converged solution. I'm using Eulerian Wall Boiling Model in Fluent. This model giving good results for flow boiling of water in a vertical tube (steady state simulation). Now I am doing for the horizontal tube. First I started with steady state, but the simulation was not converging. Then I switched to transient simulation, but still I'm not getting converged results. Hope you people have solved this problem. Please help me to do this successfully. I'll be thankful to you.
rampal is offline   Reply With Quote
Old   October 31, 2022, 02:18
SUNhaoyu
SHY22 is on a distinguished road
Originally Posted by Sid! View Post
Hi Qinh,
Hi sid! ,Im using the reactingTwoPhaseEulerFoam to simulate the Bartolomej experiment,and I encountered the same problem as you, I use the wedge boundary but the gas still produces very little, and the parameters in the literature do not match, I want to ask is the example you used in the simulation process is wall boiling? Is this happening because of a setup problem with the phaseproperties file?or thermolphaseproperties? Please give me some advice, thank you very much!!
SHY22 is offline   Reply With Quote
multiphase, phase change, reactingtwophaseeulerfoam, wall boiling
Multiphase wall boiling model omaralyahia CFX 4 July 14, 2015 21:41
Radiation interface hinca CFX 15 January 26, 2014 17:11
Quenching simulation - wall boiling model Michael.J CFX 10 August 27, 2013 17:02
Can CFX10 simulate the subcooled boiling near wall Gu Hanyang CFX 0 October 2, 2008 03:11
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
