October 10, 2017, 21:45 |
openfoam-dev interFoam/wave tutorial
Sungbae Lee
Rep Power: 8 |
Hello folks,
I am a OpenFOAM beginner and I want to make solitary wave with OpenFOAM. And I found that OpenFOAM doesn't have solitary wave model and openfoam-dev has solitary wave model. So I tried openfoam-dev interFoam/wave tutorial. In the U file, the wave model is Airy so I changed to solitary and I executed Allrun and interFoam and I got this message. Code:
--> FOAM FATAL IO ERROR: keyword offset is undefined in dictionary ".solitary" file: .solitary from line 36 to line 39. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 566. FOAM exiting Thanks!! Last edited by Tobi; October 11, 2017 at 07:34. Reason: Code tags |
October 11, 2017, 07:33 |
Tobias Holzmann
Rep Power: 51 |
Hi and welcome,
short and quick. a) Please use code tags; b) as it is written: Code:
Keep foaming, Tobias Holzmann |
October 11, 2017, 08:16 |
Sungbae Lee
Rep Power: 8 |
where can I find dictionary .solitary ?
October 11, 2017, 08:25 |
Tobias Holzmann
Rep Power: 51 |
You did the change:
In the U file, the wave model is Airy so I changed to solitary I never worked with that model but actually you activated it. More information are given in the corresponding header file. Provide a test case that we can check your problem.
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
OpenFOAM v5 tutorial interFoam wave | lsb1292 | OpenFOAM Running, Solving & CFD | 2 | September 13, 2018 02:02 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
