March 26, 2018, 04:56 |
Apply Outlet massflow on inlet
Rep Power: 10 |
Hello everyone,
I have two fluid regions seperated by a solid part. The fluids are connected with very thin channels. I want to avoid to creaty a mesh in these channels. I thought that it could be possible to define one part of the solid as outlet and on the other side as inlet to simulate the flow through the solid. Is it possible to read out the massflow on the outlet and set it up as an inlet-massflow for every timestep? I want to 'link' the regions if you know what i mean. Thank you sufjanst |
March 26, 2018, 05:14 |
Robert
Rep Power: 11 |
If i understand you correctly your domain looks something like this: [Fluid]==[Fluid]. If so, the flow through the channels will modify your local flow pattern and simply copying the left side onto right sides inlet so that [Fluid][Fluid] will not recreate the results you are looking for.
Your problem sounds like you need to model your channels, but you may get away with using shorter channels. |
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet | coolcrasher | OpenFOAM Post-Processing | 7 | November 4, 2021 04:57 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? | Zaphod'sSecondHead | OpenFOAM Running, Solving & CFD | 0 | January 28, 2015 05:17 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
Which B.C. i should apply for this problem?urgent | raivish | Phoenics | 4 | February 16, 2006 04:35 |
