Dynamic Equation for LES
Old   December 11, 2017, 13:32
Default Dynamic Equation for LES
Maheandar
Mahe512 is on a distinguished road
Hallo,
I am running the simualtion for moriyoshihomogeneous in LES model.I want to run the simualtion in dynamicKEqn.But the simualtion is not running.I ma not able to find out the problem.
The problem is shown below.Thanks in advamnce.
Build  : 4.x-ed69f631ce88
Exec   : C:/blueCFD-Core-2016/OpenFOAM-4.x/platforms/mingw_w64GccDPInt32Opt/bin/XiFoam.exe
Date   : Dec 11 2017
Time   : 18:05:37
Host   : "COOLTEK03"
PID    : 8884
Case   : C:/blueCFD-Core-2016/ofuser-of4/OpenFOAM/XiFOAM/LES/dynamicKEqn
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Reading combustion properties
Found ignition cells:
1(0)
Ignition on
Reading thermophysical properties
Selecting thermodynamics package
    type            heheuPsiThermo;
    mixture         homogeneousMixture;
    transport       sutherland;
    thermo          janaf;
    equationOfState perfectGas;
    specie          specie;
    energy          absoluteEnthalpy;
min(b) = 1
Reading field U
Creating turbulence model
Selecting turbulence model type LES
Selecting LES turbulence model dynamicKEqn
Selecting LES delta type cubeRootVol
--> FOAM Warning :
    From function void Foam::LESModels::cubeRootVolDelta::calcDelta()
    in file LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C at line 55
    Case is 2D, LES is not strictly applicable
dynamicKEqnCoeffs
    filter          simple;
    Ce              1.048;
Creating field dpdt
Creating field kinetic energy K
Creating field Xi
Creating the unstrained laminar flame speed
Selecting laminar flame speed correlation Gulders
Reading strained laminar flame speed field Su
Calculating turbulent flame speed field St
No MRF models present
No finite volume options present
Courant Number mean: 0 max: 0
Starting time loop
Time = 5e-006
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.99996, Final residual = 4.38285e-009, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.99997, Final residual = 4.38289e-009, No Iterations 1
Max St-Courant Number = 4.68332e-019
Igniting cell 0 state : 1 1 0.434 1e-015
DILUPBiCG:  Solving for b, Initial residual = 1, Final residual = 1.72459e-012, No Iterations 1
min(b) = 0.996682
We're sorry, but the application crashed and safe stack tracing isn't available in this current implementation of blueCF        D-Core patches for OpenFOAM.
Last edited by wyldckat; December 31, 2017 at 14:16. Reason: Added [CODE][/CODE] markers
Mahe512 is offline   Reply With Quote
Old   December 31, 2017, 14:19
Retired Super Moderator
Bruno Santos
Greetings Mahe512,
If possible, please upgrade to blueCFD-Core 2017-1, because stack tracing was made available with that version. That way it should at least give more details on why it crashed.
Best regards,
Bruno
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh Emanuele88 FLUENT 0 February 9, 2016 12:39
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 20:53
Need help:about energy equation in CFX Stein CFX 4 July 2, 2009 23:31
Diffusion Equation izardy amiruddin Main CFD Forum 2 July 4, 2002 09:14
