Droplets rebound or stick
Old   January 3, 2018, 15:14
Default Droplets rebound or stick
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I am looking for a way for parcels from a kinematic cloud to either stick or rebound from a particular wall patch. It looks like I can only select either of the two for one patch.
I am trying to model spray painting, where depending on the momentum and the angle of incidence of a droplet, it may stick to the surface or rebound. We are trying to investigate how these rebounding droplets may be transported with the wind into the environment.
I could find something about surfaceFilms, where droplets may be taken into the surfaceFilm and the surfaceFilm can also generate droplets to put back into the domain, however this would be too elaborate since we want to investigate many different spray locations and wind directions in a rather large domain, so prefer to stick to the icoUncoupledKinematicCloud functionObject for OpenFoam version 5.x. where we can include many more sprays in one simulation.
I hope someone has a suggestion?
Regards,
Tom
tomf is offline   Reply With Quote
Old   January 4, 2018, 03:22
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Goede morgen Tom. As far as I know this is currently not possible in OpenFOAM, and I don't know of any community contributions either, so you will have to program this yourself. Even neglecting sticking the coefficient of restitution should be dependent on angle of incidence, so it would be a nice feature to have. I will gladly review code if you'd like to develop something openly :-)
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   January 4, 2018, 04:09
Tom Fahner
Goedemorgen Anton,
Thanks for the fast response, I will have to see if there is any budget available for this within the project, but I am rather pessimistic about this. Probably we will revert to an alternative approximate droplet source.
Best Regards,
Tom
Old   January 4, 2018, 04:19
akidess's Avatar
Anton Kidess
By the way, I think the necessary changes are not to complicated fortunately (though I understand your constraints): Build on StandardWallInteraction.H, use the already present velocity vector to determine angle of incidence and momentum, and replace the constant coefficient of restitution with your case-dependent behaviour.
Old   January 5, 2018, 11:07
Tom Fahner
Hi Anton,
Thank you for the hint on the way to proceed, it resulted in that I think I have something that I can use. Unfortunately I had some issues with the whole template system, which means some solvers failed to compile after I made the changes, admittedly in a rather dirty fashion.
We will have an internal discussion next week about the way we will use the code and see if we can manage to clean it up a bit to not mess up other areas.
Enjoy your weekend!
Regards,
Tom
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 20:47
Phi error in implimenting Kepsilon in DPMFoam kinbean OpenFOAM 3 December 19, 2017 17:11
Stability and Realibility of microfluidic droplets storage in tube or storage coil devalvyas System Analysis 0 February 2, 2016 11:49
Bai model droplet-wall impact / elastic rebound crevoise STAR-CD 3 November 15, 2012 14:06
Number of Droplets per Cell viv05 OpenFOAM 2 August 11, 2009 02:35
