February 26, 2018, 04:08 |
#21 | |
Robert
Rep Power: 11 |
My guess would be, that having the \ character there is of no use and/or missplaced. |
February 26, 2018, 04:22 |
#22 |
PATRICIA NAKANWAGI
Rep Power: 8 |
type scalarCodedSource;
active yes; name radiativeHeatExchange; selectionMode all; scalarCodedSourceCoeffs { fieldNames (T); redirectType sourceTime; codeInclude #{ // Need this for Stefan-Boltzmann constant #include "constants.H" #}; codeCorrect #{ #}; codeAddSup #{ using constant:hysicoChemical::sigma; if (not isActive()) return; // Looking up model parameters scalar Qsm = coeffs().lookupOrDefault<scalar>("Qsm", 164.0); scalar rhow = coeffs().lookupOrDefault<scalar>("rho", 1000); scalar Cp = coeffs().lookupOrDefault<scalar>("Cp", 4200); scalar Rt = coeffs().lookupOrDefault<scalar>("Rt", 0.03); scalar ew = coeffs().lookupOrDefault<scalar>("ew", 0.97); // Getting source vector from equation matrix scalarField& src = eqn.source(); const volScalarField& T = eqn.psi(); // Iterating through patch word top_patch_name = coeffs().lookupOrDefault<word>("patch", "top"); const fvPatch& pp = mesh().boundary()[top_patch_name]; forAll(pp, i) { label cell_i = pp.faceCells()[i]; scalar Ai = pp.magSf()[i]; scalar Ts = T[cell_i]; // Heating src[cell_i] -= Qsm*(1-Rt)*Ai/rhow/Cp; // Cooling src[cell_i] -= -sigma.value()*ew*pow4(Ts)*Ai/rhow/Cp; } #}; codeSetValue #{ #}; code #{ $codeInclude; $codeCorrect; $codeAddSup; $codeSetValue; #}; } sourceTimeCoeffs #{ #}; radiativeHeatExchangeCoeffs { selectionMode all; patch top; // Name of the top patch Qsm 163.0; // Solar radiative heat flux Rt 0.03; // Reflectivity of water ew 0.97; // Emissivity of water rho 1000.0; Cp 4200.0; } } I modified my fvOptions file as the above following earlier errors I was getting |
February 26, 2018, 04:28 |
#23 |
Robert
Rep Power: 11 |
Looks fine to me. Whatever the problem, you could try deleting the #{ #}; part and rewriting it by hand. Might fix the problem.
/edit: To add a bit of background to my idea: Your error complains about the string "\ " in the sourceTimeCoeffs. As you can see from your dict, there is no such string. But, to my knowledge, "\ " is used by a few programs to define the beginning of a new line. maybe your OpenFOAM got confused be the editor you use or you copied the content of the dict file from this forum? If yes, simple retyping the above mentioned part might be helpful. |
February 26, 2018, 07:44 |
#24 |
PATRICIA NAKANWAGI
Rep Power: 8 |
Thanks alot RobertHB, was able to rectify the error with adding a string to my sourceTimeCoeffs. Thanks once again
April 21, 2018, 06:15 |
#25 |
Rep Power: 8 |
Hello RobertHB,
I can add a heat source in your way, but I need to add the source in specific time, and limit the duration of the source. Could you please tell me what should I do to add a 'startTime'. Thank you in advance. |
April 22, 2018, 09:43 |
#27 |
Rep Power: 8 |
Thanks a lot RobertHB.
I finally found out that, there need a conversion between mesh time and engine time in fvOption,because my simulation is for internal combustion engine |
April 22, 2018, 09:49 |
#28 |
PATRICIA NAKANWAGI
Rep Power: 8 |
Hello fcl,
Kindly give me a hand on this. An getting an error in running my case which am failing to understand Time = 0.1 DILUPBiCGStab: Solving for Ux, Initial residual = 1.50379e-12, Final residual = 1.50379e-12, No Iterations 0 DILUPBiCGStab: Solving for Uy, Initial residual = 2.30853e-12, Final residual = 2.30853e-12, No Iterations 0 DILUPBiCGStab: Solving for Uz, Initial residual = 1.86985e-12, Final residual = 1.86985e-12, No Iterations 0 Using dynamicCode for fvOption:: radiativeHeatExchange at line 29 in "/home/patricia/OpenFoam/OpenFOAM-5.0/tutorials/heatTransfer/buoyantBoussinesqSimpleFoam/solarpond/constant/fvOptions.radiation.scalarCodedSourceCoeffs" Selecting finite volume options model type radiativeHeatExchange Source: radiativeHeatExchange - selecting all cells - selected 4000 cell(s) with volume 4 DILUPBiCGStab: Solving for T, Initial residual = 1, Final residual = 0.0414164, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00369374, No Iterations 7 time step continuity errors : sum local = 1.64439e+14, global = -0.00620117, cumulative = -0.00620117 ExecutionTime = 0.05 s ClockTime = 0 s Time = 0.2 DILUPBiCGStab: Solving for Ux, Initial residual = 0.142672, Final residual = 0.00310035, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 0.050394, Final residual = 0.000837148, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 0.142672, Final residual = 0.00310035, No Iterations 1 DILUPBiCGStab: Solving for T, Initial residual = 0.205486, Final residual = 0.0128, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 0.989794, Final residual = 122.425, No Iterations 1001 time step continuity errors : sum local = 6.73093e+17, global = 21, cumulative = 20.9938 ExecutionTime = 0.13 s ClockTime = 0 s Time = 0.3 DILUPBiCGStab: Solving for Ux, Initial residual = 0.290563, Final residual = 0.0017344, No Iterations 10 DILUPBiCGStab: Solving for Uy, Initial residual = 0.29545, Final residual = 0.00188439, No Iterations 9 DILUPBiCGStab: Solving for Uz, Initial residual = 0.331798, Final residual = 0.00214973, No Iterations 10 DILUPBiCGStab: Solving for T, Initial residual = 0.0995518, Final residual = 0.00073122, No Iterations 1 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam:ICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) at ??:? #4 Foam:ICPreconditioner:ICPreconditioner(Foam::l duMatrix::solver const&, Foam::dictionary const&) at ??:? #5 Foam::lduMatrix:reconditioner::addsymMatrixConst ructorToTable<Foam:ICPreconditioner>::New(Foam:: lduMatrix::solver const&, Foam::dictionary const&) at ??:? #6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) at ??:? #7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #8 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #10 Foam::fvMatrix<double>::solve() at ??:? #11 ? at ??:? #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 ? at ??:? Floating point exception (core dumped) What could be the problem here? Thank you PATRICIA |
April 22, 2018, 10:05 |
#29 |
Rep Power: 8 |
Hello npatricia,
sorry, I'm a new foamer. According to me, you case seems failed to converge. Maybe you need to check your condition and the value of time step. |
[swak4Foam] swak4foam for fe40: fvOption library don't compile? | jf_vt | OpenFOAM Community Contributions | 7 | August 10, 2023 03:00 |
[General] Paraview crashes using "Find Data" functionality | Turbine | ParaView | 3 | May 6, 2020 22:40 |
reactingFoam fvOption ignition | khalifa | OpenFOAM Programming & Development | 8 | January 6, 2019 18:45 |
fvOption interpolation scheme | aghsin | OpenFOAM Running, Solving & CFD | 0 | June 25, 2016 09:01 |
face functionality for a DynamicList | tomislav_maric | OpenFOAM Programming & Development | 2 | November 30, 2011 18:04 |
