Question about calculating the gas holdup in the bubble column simulation of openFOAM |
March 23, 2018, 04:17 |
Super banana
Hi Foamers
I am recently doing a bubbleColumn simulation and I need to calculate the global gas holdup by using generated data files. Since the bubbleColumn is based on the Euler-Euler model mathematically, which treat the whole model as a single continuous phase. Can i therefore assume that all alpha (the volume fraction of air) is less than unity inside the bubble column, even if the cell is quite near the gas inlet area? If so what i need to do is just get rid of all the data that equals to 1 inside the alpha.air file, and calculate the average of it. Thanks for ur time! |
global gas holdup, openfoam, twophaseeulerfoam |
lagrangian bubble simulation using OpenFOAM | anirbanmondal93 | OpenFOAM Running, Solving & CFD | 0 | May 8, 2016 06:26 |
bubble gas simulation | monababaei | Main CFD Forum | 0 | February 20, 2015 06:58 |
liquid decreases in bubble column E-E simulation | jhchen | ANSYS | 1 | August 3, 2010 10:49 |
Help required for CFD simulation of Trayed Bubble Column using Fluent | art705 | Main CFD Forum | 0 | July 15, 2009 04:04 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
