May 10, 2018, 02:29 |
Constant mass flow rate in channel flow LES
Vishwesh Ravi Shrimali
Rep Power: 8 |
Hi!
I am trying to simulate channel flow simulation in OpenFOAM for constant mass flow rate. I found a test case for channel flow which uses a Code:
momentumSource Code:
fvOptions Code:
momentumSource { type pressureGradientExplicitSource; active on; //on/off switch selectionMode all; //cellSet // points //cellZone pressureGradientExplicitSourceCoeffs { fieldNames (U); Ubar ( 0.1335 0 0 ); } } Thanks in advance Vishwesh |
May 10, 2018, 03:12 |
#2 | |
Robert
Rep Power: 11 |
If you liked my answer to your question, please consider leaving a "Like" in return |
May 10, 2018, 03:15 |
Rep Power: 8 |
I actually want to make changes in the geometry and see the affect it has on the wallShearStress and I thought it would be easier to use constant mass flow rate for the analysis rather than the constant pressure.
May 10, 2018, 03:30 |
#4 | |
Robert
Rep Power: 11 |
Just use google chrome or google translate on the website
May 10, 2018, 09:10 |
Santiago Lopez Castano
Although a bit incidental to the discussion, I'm curious to know how does using a constant mass fliw rate make the analysis easier? I mean, i would expect that by virtue of Newton's second law it'd be easier to analyse and balance shear stress with pressure gradients
channel flow, constant mass flow, openfoam 3.0.x |
Mass flow rate boundary condition with negative values | hebe2u. | CFX | 1 | December 27, 2016 03:53 |
Shape Optimization Problem of Mass Flow Rate | ggc1991 | SU2 Shape Design | 1 | December 1, 2016 20:24 |
Mass flow rate boundary condition with negative values | ashtonJ | CFX | 3 | November 26, 2014 05:21 |
Wrong Pressure countors for channel flow driven by mass flow rate or press gradient | ash-khan | FLUENT | 0 | June 21, 2009 10:02 |
Constant mass flow rate / choking outlet bounardy condition | Min Zhu | Main CFD Forum | 1 | September 29, 1998 15:33 |
