rotatingWallFunction not working properly
Old   July 4, 2018, 08:41
Question rotatingWallFunction not working properly
Osman Mirza Demircan
omdemircan is on a distinguished road
Hi Foamers,
I am trying simulate a rotating cylinder at transonic speeds in 2D using rhoPimpleFoam of the OpenFOAM 5.0 code package. However, the simulation output is almost the same as a static cylinder. Below is my U file with the BC that I have used.
I have also attached a contour showing the instantaneous Ma number. Top one is static and the bottom one is with the rotating cylinder.
Am I missing something here?
|  \\    /   O peration     | Version:  4.1                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (289.25 0 0);
boundaryField
    inlet
		type	fixedValue;
		value	uniform (289.25 0 0);
    outlet
        type	zeroGradient;
    fixedWall
        type	noSlip;
    movingWall
        type	rotatingWallVelocity;
		origin	(-0.009525 0.009017 0);
		axis	(0 0 1);
		omega	104.72; // rad/s
    slip
        type	symmetry;
    empty
        type	empty;
omdemircan is offline   Reply With Quote
rhopimplefoam, rotating body, rotating cylinder
potentialFoam not working properly GAlava OpenFOAM Running, Solving & CFD 7 March 9, 2021 11:34
Is there any institutions still working on solving N-S equations? sharonyue Main CFD Forum 2 November 11, 2015 08:23
what "If" condition means in rebound brbbhatti OpenFOAM Programming & Development 0 August 12, 2014 09:18
Flapping wing rotation in Fluent 3D not working properly davesmith_01 FLUENT 1 February 13, 2011 21:35
Sample utility not working properly titio OpenFOAM 2 June 9, 2010 10:45
