July 26, 2018, 20:38 |
Cannot find patchField entry
hadi pelavar
hi
I tried to solve heat transfer with solver "buoyantBoussinesqSimpleFoam" and I changed tutorial file of that and I get following error: Reading field alphat --> FOAM FATAL IO ERROR: Cannot find patchField entry for topAndBottom file: /home/hadi/OpenFOAM/hadi-5.0/run/hotRoom/0/alphat.boundaryField from line 26 to line 46. From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] in file /home/ubuntu/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 191. and blockMesh of my problem is : convertToMeters .001; vertices ( (0 0 0) (75 0 0) (75 75 0) (0 75 0) (0 0 1) (75 0 1) (75 75 1) (0 75 1) ); blocks ( hex (0 1 2 3 4 5 6 7) (150 150 1) simpleGrading (1 1 1) ); edges ( ); boundary ( frontAndBack { type empty; faces ( (0 1 5 4) (2 3 7 6) ); } topAndBottom { type wall; faces ( (4 5 6 7) (3 2 1 0) ); } hot { type wall; faces ( (4 7 3 0) ); } cold { type wall; faces ( (6 5 1 2) ); } ); mergePatchPairs ( ); also I should say I changed the flow to laminar in turbulenceProperties : simulationType laminar; RAS { RASModel laminar; turbulence off; printCoeffs off; } cold you help me please the reason of this error??????? of course the alphat file is following dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { frontAndBack { type empty; topAndBottom { type alphatWallFunction; Prt 0.85; value uniform 0; } hot { type alphatWallFunction; Prt 0.85; value uniform 0; } cold { type alphatWallFunction; Prt 0.85; value uniform 0; } } thanks |
July 27, 2018, 11:44 |
Rep Power: 12 |
You are missing a right bracket after:
frontAndBack { type empty; } |
Cannot find patchField entry for InletWall | range_rover | OpenFOAM Running, Solving & CFD | 5 | November 18, 2020 21:21 |
decomposePar fails "Cannot find patchField entry for maxY" | JasonQuinn | OpenFOAM Pre-Processing | 2 | April 4, 2017 01:07 |
meshing of a compound volume in GMSH | shawn3531 | OpenFOAM | 4 | March 12, 2015 10:45 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
