SimpleFoam Laminar Pipe Flow Pressure Drop Error |
September 13, 2019, 08:10 |
Xiaolong Liu
Rep Power: 6 |
Hello Foamers,
I am new to openfoam. I am trying to simulate a laminar pipe flow by using simpleFoam and compare the pressure drop with the analytical solution. However, I found a quite consistent about 11% pressure drop error by adjusting the inlet velocity (Re=500, 1000, 1500, 2000) Below are the parameters I used for this simulation Pipe length (L): 0.5m Pipe diameter (D): 0.015m Dynamic viscosity (mu): 8.9e-4 N/m-s Density (rho): 997 kg/m^3 Max value of parabolic velocities: (1) 5.96e-2 m/s(Re=500); (2) 1.19e-1 m/s (Re=1000); (3) 1.78e-1 m/s (Re=1500); (4) 2.38e-1 m/s (Re=2000). Boundary conditions: p: Inlet: zeroGradient; Outlet: fixedValue uniform 0; Wall: zeroGradient; U: Inlet: parabolic velocity (I tried fixedvalue uniform inlet velocity as well without measuring in the entry length region, the same problem); Outlet: zeroGradient; Wall: fixedValue uniform (0 0 0); I also compared simulation results with Fluent, as shown in the figure below: https://www.dropbox.com/s/22xv8hlwuv...luent.png?dl=0 I have tried (1) refining the mesh in different levels; (2) adjusting the gradient scheme to leastsquares method; (3) importing the mesh developed in ANSYS for Fluent simulation. None of these can change the results. Since this is a very simple case, I believe simpleFoam should be able to provide accurate prediction on the pressure drop. However, I just can not get it. I really appreciate if anyone can help to point out what the problem is. Please find my code in the following link: https://www.dropbox.com/s/w91ak3klx3..._flow.zip?dl=0 Thanks, Xiaolong |
September 16, 2019, 08:26 |
Xiaolong Liu
Rep Power: 6 |
Anyone has some insight in this?
September 16, 2019, 09:57 |
Rep Power: 20 |
Your viscosity in transportProperties ("1e-06; //water")
does not match what you specified Code:
Dynamic viscosity (mu): 8.9e-4 N/m-s Density (rho): 997 kg/m^3 |
September 16, 2019, 10:37 |
#4 | |
Xiaolong Liu
Rep Power: 6 |
Thank you very much. I didn't realize I messed up with my data. Now it's matching. Best, Xiaolong |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
