October 15, 2019, 23:01 |
reactingFoam SandiaD_LTS tutorial error
Fantastic Boy
Rep Power: 8 |
Hi all. I am using OpenFOAM 6 and I am trying the tutorial SandiaD_LTS. I just use the Allrun file to start the simulation without modifying any parameters. However, there is error for the setFields which shows below.
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-fa1285188035 Exec : setFields Date : Oct 16 2019 Time : 10:47:04 Host : "mgt-aaibe" PID : 30000 I/O : uncollated Case : /home/mgt-aaibe/OpenFOAM/mgt-aaibe-6/run/combustion_test nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 1500 Reading setFieldsDict Setting field default values --> FOAM Warning : From function bool setCellFieldType(const Foam::word&, const Foam::fvMesh&, const labelList&, Foam::Istream&) [with Type = double; Foam::labelList = Foam::List<int>] in file setFields.C at line 117 Field T not found --> FOAM Warning : From function bool setCellFieldType(const Foam::word&, const Foam::fvMesh&, const labelList&, Foam::Istream&) [with Type = double; Foam::labelList = Foam::List<int>] in file setFields.C at line 117 Field N2 not found --> FOAM Warning : From function bool setCellFieldType(const Foam::word&, const Foam::fvMesh&, const labelList&, Foam::Istream&) [with Type = double; Foam::labelList = Foam::List<int>] in file setFields.C at line 117 Field O2 not found --> FOAM Warning : From function bool setCellFieldType(const Foam::word&, const Foam::fvMesh&, const labelList&, Foam::Istream&) [with Type = double; Foam::labelList = Foam::List<int>] in file setFields.C at line 117 Field CH4 not found Setting field region values Adding cells with center within boxes 1((0 -10 -100) (0.0036 10 0)) --> FOAM Warning : From function bool setCellFieldType(const Foam::word&, const Foam::fvMesh&, const labelList&, Foam::Istream&) [with Type = double; Foam::labelList = Foam::List<int>] in file setFields.C at line 117 Field CH4 not found --> FOAM Warning : From function bool setCellFieldType(const Foam::word&, const Foam::fvMesh&, const labelList&, Foam::Istream&) [with Type = double; Foam::labelList = Foam::List<int>] in file setFields.C at line 117 Field O2 not found --> FOAM Warning : From function bool setCellFieldType(const Foam::word&, const Foam::fvMesh&, const labelList&, Foam::Istream&) [with Type = double; Foam::labelList = Foam::List<int>] in file setFields.C at line 117 Field N2 not found End |
July 6, 2020, 18:13 |
hi there;
i had the same problem but I could fix it, if you still want fixing the problem I can help |
December 6, 2020, 08:34 |
Haynes
Rep Power: 5 |
I know, it's a late reply. But incase you need it, you can find the documentation and simulation files for Sandia D flame tutorial
https://www.cemf.ir/reactingfoam-how...e-by-openfoam/ |
December 6, 2020, 18:27 |
Hi;
Thank you very much for you replay, it is very useful thanks again. |
February 9, 2021, 08:09 |
serg
Rep Power: 10 |
December 6, 2021, 14:00 |
abdikerim kurbanaliev
Dear all. I am using OpenFOAM 7 and I am trying the tutorial SandiaD_LTS without any modification. I just used the Allrun file to start. But I have Floating point exception (core dumped) error after 3719 iteration.
Could you help me? |
December 20, 2021, 18:19 |
"cannot find patchField entry" problems for SandiaD_LTS
Uğur
Rep Power: 4 |
Hello everyone, I am new to openfoam and need to simulate nonpremixed combustion in openfoam-9, for this ı select SandiaD_LTS solver
1 .I created axi-symmetric cylinder geometry for 2D case on Salome-Meca 2015, also used seperated small angle (3 degre) wedge planes, 2 .I created patchfiled for inletCH4 (patch), inletair(patch), outlet (patch), frontandBack_pos (wedge) ,frontandBack_neg (wedge) 3. for meshing I used Netgen 2d3d algorithm and 3d parameters hypotheses 4. Exporting .unv mesh file to openfoam 5. I used chemkinToFoam, ideasUnvToFoam, so that constant/polymesh file is appeared, checkMesh is OK , 6. After that, I arranged system/setFieldsDict for initializing inletCH4 field and running reactinFoam, so I encountered the following message; --> FOAM FATAL IO ERROR: Cannot find patchField entry for frontandBack_pos file: /home/ugur/OpenFOAM/ugur-9/run/SandiaD_LTS/0/T/boundaryField from line 25 to line 52. From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184. FOAM exiting about the message, also I selected wedge patch type for frontandBack_pos and frontandBack_neg in constant / polyMesh /boundary 6 ( inletCH4 { type patch; nFaces 7; startFace 64411; } inletair { type patch; nFaces 20; startFace 64418; } outlet { type patch; nFaces 27; startFace 64438; } wallTube { type patch; nFaces 593; startFace 64465; } frontandBack_pos { type patch; nFaces 12980; startFace 65058; } frontandBack_neg { type patch; nFaces 13215; startFace 78038; } ) and, also I selected initial temperature for my boundaryField in 0/T , as like this ; dimensions [0 0 0 1 0 0 0]; internalField uniform 295; boundaryField { inletCH4 { type fixedValue; value uniform 295; } wallTube { type zeroGradient; } inletair { type fixedValue; value uniform 295; } outlet { type zeroGradient; } frontAndBack_pos { type wedge; } frontAndBack_neg { type wedge; } } I feel so helpless and tired. Does anyone have a solution for this issue or have encountered this type of problem? Thank you for your help in advance. |
January 11, 2022, 10:11 |
#8 | |
Julio Pieri
Rep Power: 8 |
Seems that you have a lower case problem there. Your mesh is defined with frontandBack_pos, while your BCs are frontAndBack_pos |
January 13, 2022, 07:24 |
Uğur
Rep Power: 4 |
Julio, thanks for attention first of all, You're right, I realized latter. For meshing I used blockMesh utility instead of Salome, Netgen algorithm. Becasuse of this, I annihilated skewness and ortogonality problems. But, ı have a new problem about initial k-epsilon values
January 13, 2022, 12:15 |
Julio Pieri
Rep Power: 8 |
For that you check the OF user guide or other regular resources. There are typical calculations for that!
January 26, 2022, 20:07 |
#11 | |
Sanjan
Rep Power: 4 |
I am facing the same. |
January 27, 2022, 04:27 |
#12 |
January 27, 2022, 08:40 |
#13 |
Sanjan
Rep Power: 4 |
Thank you for letting me know. Could you mention which version seems to work because OpenFOAM v6 did not produce accurate results as mentioned in Sandia Flame D OpenFoam tutorial case - bad result?
I wonder if a particular version produces accurate results. Thank you again |
January 27, 2022, 09:40 |
#14 | |
January 27, 2022, 18:19 |
#15 | |
Sanjan
Rep Power: 4 |
Thank you for your suggestions! |
January 28, 2022, 01:10 |
#16 | |
reactingfoam, tutorial |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
