multiphaseEulerFoam - sensitive to many parameters (unphysical results)
Old   October 21, 2019, 22:12
Default multiphaseEulerFoam - sensitive to many parameters (unphysical results)
Alejandro
ancolli is on a distinguished road
I am running multiphaseEulerFoam for a 2D channel with a given inlet water velocity and inlet air from porous walls.
I am obtaining totally different results if I use constant deltaT or variable deltaT (Co < 0.2). Also, I obtained different results by changing nCorrectors from 1 to 2 or 3, or by modifying nOuterCorrectors (a different result for each setting...)
Finally, modifying residualPhaseFraction and residualSlip change a lot the final steady-state solution.
Does anyone know what is happening? Am I doing something wrong?
Does anyone know a validation case for multiphaseEulerFoam? Because all tutorials I saw and even some research papers just show colors ("phases") mixing together...
ancolli is offline   Reply With Quote
Problem: Very long "write" time (~2h-3h) for results and transient results Shawn_A CFX 16 April 12, 2016 20:49
Transient Run - Output "Time" in partial results? evcelica CFX 2 May 16, 2012 21:36
results on wall force (expert parameters) syafiq CFX 1 October 5, 2011 05:35
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
Comparison between turbulent parameters with analytical or experimental results fareedmangi FLUENT 0 June 2, 2009 10:41
