Allrun in background
Old   November 30, 2016, 03:14
Default Allrun in background
Hagen
HagenC is on a distinguished road
Hi everyone,
I have a question concerning the Allrun script in background mode. Running Allrun redirects the output to log files, but still the command window is blocked for new commands. I tried running the script in background by
./Allrun &
But still the command window is blocked.
Thank you for your help.
HagenC is offline   Reply With Quote
Old   November 30, 2016, 16:41
Rodrigo
guin is on a distinguished road
simplest way: edit the script Allrun, so that it uses foamJob utility.
Replace the line where the solver call appears (i.e. runApplication $yourSolverName)by:
foamJob $yourSolverName
in case of working in parallel you shall rather use
foamJob -parallel $yourSolverName
(no need to specify the number of processes, that is read automatically from system/decomposeParDict)
other (less recommended) possibilities:
a. stop process and send it to background manually
./Allrun &
Ctrl+Z
bg
b. use nohup utility:
nohup ./Allrun &
guin is offline   Reply With Quote
Old   January 9, 2017, 04:53
Hagen
Thank you very much for your reply.
foamJob works, but then I get another problem when using several commands that should be executed one after another, like in the following example:
foamJob snappyHexMesh
foamJob simpleFoam
The execution of simpleFoam does not wait until snappyHexMesh is finished.
I tried
wait
foamJob simpleFoam
But without success.
Has someone an idea on that?
Thank you very much.
Old   January 9, 2017, 05:07
Rodrigo
foamJob simpleFoam
I tried
wait
foamJob simpleFoam
that is because foamJob executes the process in the background, so the next command does not have yo wait for it to finish before being executed. Try out to call snappyHexMesh using "runApplication" instead of "foamJob" .
Old   January 9, 2017, 05:10
floquation's Avatar
Kevin van As
floquation will become famous soon enough
What exactly does your script look like?
If I have a prepareCase script like:
##### Prepare Case #####
echo "> Preparing case."
if [ ! -d "./logs" ]; then
    mkdir "./logs"
fi
[ -d 0 ] && 'rm' -rf 0
cp -r 0.org 0
# Mesh
echo "----> blockMesh"
blockMesh > ./logs/blockMesh.log || exit 1
# setFields
echo "----> setFields"
mv "0/alpha.water.org" "0/alpha.water"
setFields > ./logs/setFields.log || exit 1
I can run it in the background by:
./prepareCase.sh &
Or silently:
./prepareCase.sh > log &
All commands inside the prepareCase.sh script are executed sequentially - as they should.
If this is not the case for you, I presume that you have inserted some background "&"s inside the script?
floquation is offline   Reply With Quote
Old   January 9, 2017, 05:27
Hagen
Thank you again for your very quick answers!
My original ./Allrun file was:
#!/bin/sh
cd ${0%/*} || exit 1
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
runApplication blockMesh
runApplication surfaceFeatureExtract
runApplication snappyHexMesh -overwrite
runApplication simpleFoam
runApplication foamToVTK
And had the problem of blocked command window as described in the first post. So I changed the ./Allrun file to:
#!/bin/sh
foamJob blockMesh
foamJob surfaceFeatureExtract
foamJob snappyHexMesh -overwrite
foamJob simpleFoam
foamJob foamToVTK
And had the problem of waiting for the previous job to be finished as described in the second post. By changing it to:
#!/bin/sh
foamJob simpleFoam
Then the problem is the foamToVTK not being executed after the solution process. Further I would like to have the snappyHexMesh also running in the background.
Cheers.
Old   January 9, 2017, 06:26
Rodrigo
You original Allrun file was OK. You can just call it by using one of my previously called "less-recommended" options "a" or "b" (post #2):
Personally, I would use option "a" because I don't like the logfile written by nohup.
Your second version of the Allrun file is definitetly not a good idea. Short (and surely oversimplified) hint: use foamJob only for calling the solver and ensure that it is the last action in your Allrun file.
There would be more possibilities of having it done, but I think there is no point on getting more into deep on this in this forum, provided the given options shall just work and have the additional advantage of being simple...
Last edited by guin; January 9, 2017 at 06:29. Reason: added link to previous post
Old   January 9, 2017, 08:28
Hagen
Yes, thanks guin.
Version a is exactly what I needed.
Old   November 26, 2019, 04:09
Arne
arsimons is on a distinguished road
    mkdir "./logs"
fi
cp -r 0.org 0
# Mesh
# setFields
./prepareCase.sh &
Or silently:
Hello Foamers!
I am currently trying to work on a local cluster via ssh. I was just wondering about the advantage of using the standard 'Allrun' script which has a header and uses 'runApplication', as compared to the script I quote from floquation?
Thanks in advance.
Best regards
Arne Simons
arsimons is offline   Reply With Quote
allrun background
A few questions about Gmsh: Background Mesh and Tutorial 7 SeanQuallen Main CFD Forum 2 November 27, 2017 03:28
Overset: refine background mesh without resetting the mesh JohnAB STAR-CCM+ 6 May 19, 2014 13:48
[Gmsh] background mesh in gmsh Nick_J OpenFOAM Meshing & Mesh Conversion 1 March 20, 2013 04:20
Background Image in Post ellevset CFX 4 April 1, 2009 11:01
Change Background Color Anindya Siemens 3 February 26, 2001 11:40
