December 9, 2019, 13:01 |
TJunctionFan tutorial & fanPressureJump BC
Lorenzo
Rep Power: 7 |
I want to integrate a fan in a complex simulation. The fan will be positioned after a porous media in a duct. In order to undestand fanPressureJump BC I looked into TJunctionFan tutorial. I see that I have to set
Indeed this is how the topoSetDict looks like: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name cyclicFacesFaceSet; type faceSet; action new; source boxToFace; // Select all face with faceCentre within bounding box sourceInfo { box (0.099 -0.006 0.004)(0.101 0.006 0.016); } } { name cyclicFacesSlaveCells; type cellSet; action new; source boxToCell; // Select all cells with cellCentre within bounding box sourceInfo { box (-10 -10 -10)(0.1 10 10); } } { name cyclicFaces; type faceZoneSet; action new; source setsToFaceZone; sourceInfo { faceSet cyclicFacesFaceSet; cellSet cyclicFacesSlaveCells; } } ); The red box is the one connected with "cyclicFacesSlaveCells", therefore it selects all the cells in front of the domain. My real problem is that I don't understand what "slave cells" are. And in addition, should I select all faces in front of the fan in my case too? Dose it makes any sense to define cells "in front" of the fan when, outside the duct, cells behind are direcly connected to cells in front? I tested different box dimensions that select only part of the domain in front of the fan. The results are very different. From the left:
What do you suggest? Are there easier BC to use? |
December 10, 2019, 05:56 |
anonymous
Rep Power: 14 |
Hi!
As I remember you can just use snappy for example, and create the faceZone for that baffle. Than use the createBaffles utility and you have your patches. This tutorial collects the cells near the face to explicitly determine the orientation of the cyclic faceZone (If I'm correct). This orientation will determine the the master and slave face (which new patch will be the master and which is the slave) after you create the cyclic patches ("split the mesh" with createBaffles). Sadly I don'T remember which will be the master and slave side, but you can easily test it. |
December 12, 2019, 16:11 |
Lorenzo
Rep Power: 7 |
Thank you for your fast response!
So I have to select all the domain in front of the car? (like in the picture) |
December 13, 2019, 02:46 |
anonymous
Rep Power: 14 |
How do you generate the mesh? snappyHexMesh?
First of all you just need a faceZone on the fan. Collect the faces where you have the fan into a faceZone. You don't need any cells (at least yet). Then on this faceZone you can use the createBaffles utility which will create 2 cyclic patches from this faceZone. And on these patches you can define the fan BC. The same as in the tutorial. If it works, than you should care about the orientation of the faceZone. I suggest that always do only small steps if you do something which is new for you, because you wont find the problem (probably there will be a user error ) In the tutorial they select cells, because they set the orientation of the faceZone with this method. But if you are using sHM, you don't need that. And also it is pretty difficult on a more sophisticated geometry. |
April 28, 2020, 12:17 |
Lorenzo
Rep Power: 7 |
I solly I disappeared but I had to "pause" my project.
Now I'm back on it. I managed to create 2 baffle patch (master & slave) and then I obtained the cyclic boundary with createPatch. By doing so I also have the faceZones defined by snappy. Now I really don't know how to determine the orientation of the master and slave faces. |
tutorial files | KITetima | FLUENT | 8 | November 23, 2019 16:05 |
AMI - Propeller Tutorial diverging | kingmaker | OpenFOAM Running, Solving & CFD | 2 | November 4, 2016 02:57 |
[Other] TJunctionFan tutorial question about changing baffle/outlet? | massive_turbulence | OpenFOAM Meshing & Mesh Conversion | 1 | April 17, 2014 00:07 |
Fluent Tutorial Guide Ch. 17: Non-Premixed Combust, THTR | MAE7509 | FLUENT | 0 | January 22, 2014 20:59 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 03:25 |
