dsmcFoamPlus Read Point-Specified Inlet BC from File |
February 23, 2020, 10:59 |
Andrew Weaver
Hey everyone,
I am using dsmcFoamPlus solver provided with OpenFOAM-2.4.0-MNF-1.0.1 package, and I am looking for an inlet boundary condition that reads point data from a file in a similar manner as timeVaryingMappedFixedValue. The intent is to be able to run a continuum solver, output data at a slice location where the flow becomes rarefied, and then read that data as inlet properties for the dsmcFoamPlus solver. I have searched through this forum but was unable to find any documentation of this capability for dsmcFoam. Does anyone have or know of this capability in any version of OpenFOAM? If not, I am also open to general advice on how to implement (I am new to OpenFOAM). Thanks, Andrew |
June 29, 2020, 08:51 |
ano
Rep Power: 10 |
In case it still helps someone: dsmcFreeStreamInflowFieldPatch You could map your slice data to the boundary of a field and use it as input. Otherwise it is possible to use an arbitrary mesh interface. |
boundary condition, dsmc openfoam dsmcfoam, dsmcfoam+, inlet flow profile |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
