I can not get SimpleFoam Simulation to Converge no Matter what I try |
June 15, 2020, 04:34 |
NotApplicable
I've been going at this for weeks now, and it's just frustrating at this point, I've remeshed it 3 times, and tried every conceivable combination of simulation parameters, and the forces just continue to shoot off to infinity with no rhyme or reason.
Anyway, if someone can take a look and possibly point out something it could be, I would really appreciate it. Here is the geometry, I'm using a cylinder "wind tunnel" right now, but I originally was using a square cross-section, remeshed that. I optimize it in gmsh. See this post for how I was originally able to convert from gmsh to openFoam: Gmsh trouble converting to openFOAM? Geometry: https://imgur.com/a/l1Sm27U When I try to run it using just simpleFoam, I don't see any residuals shooting off to inifity, it's just that the force coeffs and general timestep continuity starts to shoot off as well: https://i.imgur.com/QpsWXmR.png Similar thing happens, but happens sooner when I run potentialFoam first: https://i.imgur.com/FSnCf5y.png Here are all the initial condition files: https://imgur.com/a/u93VaAU Relavent system files: https://imgur.com/a/gcKRr2k boundary mesh file: https://i.imgur.com/G9X9g7j.png Any help would be really appreciated because at this point, I'm about ready to give up on openFoam. |
June 16, 2020, 13:46 |
Klaus
Rep Power: 22 |
what do you try to simulate? What's the Reynolds number? Did you update the turbulence properties? Do you have a good boundary layer mesh with appropriate y+ ? Can you show the residual plot using pyFoam? I assume you tried to modify the simpleFoam motorBike case? Klaus |
Flashback in simulation of propane-air premixed combustion using CONVERGE | DongMei | CONVERGE | 5 | January 23, 2023 07:37 |
Issue when viewing engine simulation from Converge | MMatt | EnSight | 0 | December 18, 2019 04:54 |
Steady microchannel simulation with simpleFoam | NiFl | OpenFOAM Running, Solving & CFD | 0 | April 29, 2015 05:32 |
converge condition for simpleFoam | EmadTandis | OpenFOAM Running, Solving & CFD | 8 | December 17, 2011 11:23 |
discontinous pressure at the corners of a nozzle simulation (simpleFoam) | svchb | OpenFOAM | 3 | October 15, 2011 02:20 |
