June 15, 2020, 11:09 |
compressibleInterFoam and rotating mesh
Mat
Rep Power: 14 |
Dear Foamers,
I want to perform a compressible VOF simulation of water and gas within a mixer. Starting from the mixerVesselAMI tutoriel, initialy given for interFoam (incompressible case), I updated the case for compressibleInterFoam. However, the simulation crashes at initialization, just after selecting the thermodynamics package of my gas, with a segmentation fault. Interestingly, I have seen that: 1. If I use a constant density for the equation of state, it works! It's only with perfect gas or other EOS that it crashes. 2. If I run a steady MRF computation without cyclic AMI condition at the interface between the rotor and stator zones, it works too! So I have the feeling that something's missing for the computation of thermodynamic variables in case of rotating grids. Has anyone experienced something like that ? Regards, Mat |
Rotating Mesh - Mesh Overlap/Discontinuity At Boundary Interface | sai95kamal | FLUENT | 1 | June 15, 2020 08:58 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
[ICEM] Rotating Mesh and export Mesh | ahmadreza | ANSYS Meshing & Geometry | 10 | July 12, 2015 04:17 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
