particle-laden flow simulation using DPMFoam: turbulent dispersion is not heppening |
January 8, 2021, 22:00 |
#21 | |
Shuo Mi
Rep Power: 5 |
I think you are right about the direction of gravity, then I tried all kinds of boundary conditions, meshes, and dispersion model. They didn't work. The results are the same as yours - particles not right but the fluid velocity is right compared with the experiment. Now I will try another experiment which is particle dynamical movement in a ventilated room to validate the DEM model of OpenFOAM, to see if the phenomenon we got in OpenFOAM in the backward-case is individual one. Thanks. Regards, Shuo |
January 11, 2021, 05:10 |
#22 |
Rep Power: 5 |
Hello Shuo
So far, i couldn't find any problem in my case but unfortunately particle dispersion is not occurring as expected. Anyway good luck for new case and keep me updated about your progress. Best Regards Atul |
January 13, 2021, 08:06 |
#23 | ||
Shuo Mi
Rep Power: 5 |
When I tested another case, the results are still not very good. What I compared is the particle concentration in a ventilated room. I doubt I calculated the concentration wrong. I calculated it in this way: Quote:
Thanks! Regard, Shuo |
January 13, 2021, 08:28 |
#24 |
Rep Power: 5 |
Hello
As i don't know the details about your ventilation case, I cant really say about your code regarding concentration calculation. Regarding BFS case, I extracted particle ID, velocity and position at certain time (say 0.07 sec after insertion of particles). The extracted data are evaluated at slice around each measurement location (x/H=2,5,7,9,12) keeping the measurement location at center of slice. Now you have particle distribution along y direction in each slice. Now you can plot particle velocity profile for the particle in that slice. I extracted particle data exactly the same way done by Greifzu et.al. You should read the paper of Greifzu et.al.: https://www.tandfonline.com/doi/pdf/...0.2015.1104266 Best Regards Atul |
May 10, 2021, 09:32 |
#25 |
YANG Lu
Rep Power: 5 |
Hi, atul1018. Did you solve the problem? I have met the same problem recently. I also found that the particles in the Y-axis direction do not settle down. If you have found the solution, could you please share your method? Thanks a lot.
May 11, 2021, 23:04 |
#26 | |
YANG Lu
Rep Power: 5 |
May 12, 2021, 04:41 |
#27 | |
Rep Power: 5 |
Hey YANGLU1021
May 13, 2021, 22:20 |
#28 |
YANG Lu
Rep Power: 5 |
Thanks for your reply. I will try some ways to see if this situation can be improved. I will tell you if I get any progress. Thanks and have a good day!
dpmfoam, komegasst, particle-laden flow, rans model |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Turbulent dispersion in Lagrangian particle tracking | cvh | CFX | 0 | October 29, 2015 12:19 |
Beginner level doubts with turbulent flow simulation setup | Sagun | OpenFOAM | 1 | October 22, 2012 09:56 |
Turbulent Dispersion in Particle Tracking | ariel | CFX | 2 | April 22, 2008 22:02 |
