Conflicting Lift and Drag coefficient values in OpenFoam |
September 12, 2020, 10:07 |
Akin AKinneye
Rep Power: 7 |
I am trying to re-validate an incompressible flow over the NACA 23012 airfoil using OpenFOAM and the values of lift coefficient are conflicting with the values from experiment and the previously conducted simulation in ANSYS Fluent I carried out.
Now, the mesh is the same one I created in ICEM CFD which I exported into OpenFOAM using fluentmeshtofoam. So I'm not exactly sure it's a problem of mesh accuracy but I'm happy to be proven wrong. I used the same BCs and turbulence model as well. The lift coefficient values from experiment and previous simulations are roughly 0.55 while the one I'm getting is 0.26. Please help. Thanks |
October 15, 2020, 17:46 |
Klaus
Rep Power: 22 |
Can you provide your case file or at least a description of the case and your setup.
There are many factors that can play a role: mesh, solvers and turbulence models and their specific implementation, settings, initial conditions... |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
drag coefficient (Cd) and lift coefficient (Cl) Values problem | flughafen | OpenFOAM | 0 | April 5, 2019 11:12 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
Lift and drag coefficient with strange values for NACA airfoil | antonio_ing | OpenFOAM Running, Solving & CFD | 16 | September 13, 2012 12:21 |
Strange values for Lift & Drag Coefficient | recnice | OpenFOAM Running, Solving & CFD | 3 | November 18, 2011 20:31 |
