looking for explanation of v2012 simpleCar tutorial |
July 21, 2021, 13:42 |
Alan w
Rep Power: 6 |
Currently I am trying to learn how to simulate airflow through car radiators. There is a tutorial in v2012 called simpleCar which addresses this. btw, I previously posted a thread, "trouble running simpleCar case" which referred to one of the issues. But what I really need is an explanation of the methodology and parameters that are associated with defining a heat exchanger, as used in this tutorial. For example, one of my questions regards the definition of the 'airIntake'. I have attached a powerpoint file that shows an image from paraView. It shows how a small portion of the radiator ducting has been captured by a box, and is assigned a face name, 'airIntake'. Why only a small part of the ducting, and does it matter which part of the ducting it comes from? Is 'airIntake' hard coded terminology, or could it be called 'ducting'? Another one regards the intake definition in 0/U, which follows: Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (10 0 0); // Surface normal with time ramping intakeType1 { type surfaceNormalFixedValue; refValue uniform 1.2; ramp table ((0 0) (10 1)); } // Uniform surface normal with Function1 for ramping intakeType2 { type uniformNormalFixedValue; uniformValue table ((0 0) (10 1.2)); } // Uniform surface normal with time ramping intakeType3 { // Or directly with uniform value (ramping also possible) type uniformNormalFixedValue; uniformValue constant 1.2; ramp table ((0 0) (10 1)); } If anyone is familiar with this tutorial and/or simulating airflow through heat exchangers, I would appreciate some help/directions to an information source. |
tutorial files | KITetima | FLUENT | 8 | November 23, 2019 16:05 |
AMI - Propeller Tutorial diverging | kingmaker | OpenFOAM Running, Solving & CFD | 2 | November 4, 2016 02:57 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 03:25 |
CFD-ACE Tutorial for Serpentine Fuel cell Channel | Taqi | Main CFD Forum | 0 | April 13, 2008 13:12 |
Rotor/stator tutorial, and how to... | gilberto | CFX | 5 | January 21, 2002 09:41 |
