how to access windows files from openfoam v2012 |
August 8, 2021, 18:03 |
Alan w
Rep Power: 6 |
Although I'm a newbie with OF8, I'm even more of one for v2012. I have some text files that I want to use to create a case in the windows version. But I can't figure out how to access them from OF v2012. I think it involves something like a mnt/c command, but I can't make it work. Sorry for such a basic question, but after researching, I'm still stumped. Hope someone can save me from the spectre of vi-ing them in. |
August 9, 2021, 04:53 |
Niklas Boehnke
Rep Power: 4 |
Hi Alan,
are you using a virtual box or the ubuntu subsystem? |
August 9, 2021, 07:03 |
Petros Ampatzidis
Rep Power: 7 |
If you are using WSL, you can navigate to the ubuntu files with: Code:
cd /mnt/c/Users/<USERNAME>/AppData/Local/Packages/CanonicalGroupLimited.<UBUNTUVERSION>/LocalState/rootfs/home |
August 9, 2021, 11:34 |
Alan w
Rep Power: 6 |
Thanks petros and janibo,
The system that I'm having trouble with is OpenFOAM Min GW cross-compilation; this is the WSL version, I believe. While in this OpenFOAM, I need to be able to read native windows10 files, but haven't found the method. Also I run OpenFoam8 via Ubuntu on virtual box; for this one I have a bridge to the windows files, so it's no problem. I think it's similar to what petros has suggested. But the problem remains: how to bridge between native windows10, and WSL OpenFoam? |
August 10, 2021, 03:48 |
Yann
Rep Power: 26 |
Hi Alan,
What Petros is talking about is referenced as "Windows 10 native (WSL)" What you are using is "Windows - minGW" installation which is, I guess, different. I cannot really help with that since I never used it. On windows I usually go for WSL which is quite easy to use and works for both ESI-OpenCFD and Foundation versions. I find it easier than setting up a virtualbox. By the way, if you are already using OpenFOAM-8 on a virtualbox, why not installing OpenFOAM-v2021 on the same virtualbox? It would save you the effort of setting up 2 different installations for OpenFOAM-8 and v2012 and you could seamlessly switch from one version to another. (same goes for WSL where you can use both versions) ---- Just in case some people might be interested, here are clarifications about filesystems under WSL: In WSL, your windows filesystem is accessible from /mnt/c. From there you can navigate in your windows files. So you can setup your cases from the windows explorer pretty much wherever you want. For instance, something like /mnt/c/USER/OpenFOAM-run. You can also access your linux filesystem through the windows explorer following the path given by Petros: /mnt/c/Users/<USERNAME>/AppData/Local/Packages/CanonicalGroupLimited.<UBUNTUVERSION>/LocalState/rootfs This makes things pretty easy to share files from both windows and openFoam-linux environments. ---- I hope this helps, Yann |
August 11, 2021, 06:08 |
Niklas Boehnke
Rep Power: 4 |
You could either try the:
explorer.exe . command for direct access. or you could try a shared (linked) folder with: ln command. https://superuser.com/questions/1083...side-of-ubuntu |
August 12, 2021, 02:38 |
Rep Power: 9 |
If you're using Windows 10 MinGW cross-compiled OpenFOAM2012, you can access your windows file system like this..(c, d is drive letter in windows)
ls -l /c/Windows cp /c/Windows/write.exe /d/testDirectory |
[mesh manipulation] Multi-region mesh from .stl files in OpenFoam V7 | carl_r | OpenFOAM Meshing & Mesh Conversion | 7 | January 4, 2024 09:02 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
[Gmsh] gmshToFoam on openfoam windows version of OpenFOAM v1812? | SihunLee | OpenFOAM Meshing & Mesh Conversion | 0 | June 17, 2019 05:44 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
