Thermal contact resistance with variable thickness
Old   August 9, 2021, 11:30
Default Thermal contact resistance with variable thickness
C_Morales is on a distinguished road
Hello everyone,
I am trying to model the contact resistance between two bodies. I know that the "turbulentTemperatureCoupledBaffleMixed" is the way to go except I have a unique issue where the thickness between the two objects varies.
My question is: Is it possible to simulate a variable thickness for the thermal contact resistance? And if so, how?
Unfortunately I cannot share the case file as it is sensitive but this is what I have in my 0/T folder for the said BC:
targetToCopper
type compressible::turbulentTemperatureCoupledBaffleMix ed;
value $internalField;
Tnbr T;
kappa solidThermo;
kappaName none;
thicknessLayers (2.5e-7); //Use average since cannot make variable
kappaLayers (0.016);
Basically what I want is to have my layer thickness follow a certain function dependent on coordinates, for example:
thickness = f(x,z coordinates)
Any help is definitely appreciated. Thanks!
C_Morales is offline   Reply With Quote
Conjugate Heat Transfer: Contact Thermal Resistance on Both Patches bikooo3878 OpenFOAM 6 August 22, 2023 03:59
Thermal Stress - Modelling of an interactive coupled Simulation macRC Structural Mechanics 0 January 10, 2019 05:14
Solid-Solid thermal resistance layer thickness Adam_K OpenFOAM Pre-Processing 2 November 14, 2018 23:56
UDF for viscous resistance for porous media with time variable benson621 Fluent UDF and Scheme Programming 2 November 24, 2011 11:59
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
